Results 1 to 2 of 2
- 17
November 11th, 2002 09:49 PM #1Ano ba problema pag hard starting sa umaga ang sasakyan? pero pagstart tuloy tuloy naman. Lalo na kung malamig panahon. Injection o makina?
November 11th, 2002 10:07 PM #2
Pwedeng:
1. Mahina na battery mo. Have it checked.
2. Baka sira na glow plugs mo. Umiilaw ba glow plug sign once you set the ignition to on?
3. Problem with the starter motor.
4. Baradong fuel injector
5. It's normal in very cold weather for hard starts to occur. When the engine heats up, ok na.
Have it checked with your suking mekaniko. Goodluck. :D
high idle RPM at engine start
