Mga bro..
I just want to ask if wat problem ng liteace ko...amoy gas after off ng engine.
minsan parang lunod sya pag start mo. pero pag mga 2-3 hrs na sya naka off den iistart one clik lang ok na. ano po kya problem ne2?
Mga bro..
same here. pagpatay ng engine ganon na ganon amoy gasolina pero di matagal parang nangamoy lang... kakapalit ko lang plugs at tapos na PMS niya. ala ba connection sa pagtiming non??? di kasi ganon dati pero ngayon may amoy na.. rides ko pala nissan super saloon 1.6 engine. thanks mga bro.
Originally Posted by finchy18
baka nga siguro kasi kakatiming ko lang at di siguro tama ang pagkakatiming. di rin kaya?? pero ganda naman ng performance ng oto ko sa pagkatiming nila.
My 50cents...The smell of gasoline vapors after a failed start may mean you have flooded the engine. Wait a few minutes before trying again. If the odor persists, chances are there's a leak in the fuel system - a potential problem that needs immediate attention.
The hard starting could also be a bad fuel pump check valve. The fuel pump check valve is supposed to maintain fuel pressure when the engine is off to make starting easier.
One way to confirm this is to cycle the key OFF - ON three or four times for five seconds before actually starting the engine. If, after doing this, the engine starts right up, then it is very likely a bad fuel pump check valve or fuel pressure regulator.
check nyo din fuel tank ninyo. see if there are leaks, yun natunaw na yun undercoat, sometime sa ibabaw yun leak where the float is mounted. delikado yan especially now mainit ang panahon. parking it on a dry grassy area and a lit cigarette butt is a deadly combination.
Originally Posted by afrasay
ok n mga sir... may singaw sa kalburador...palit lang gasket ok na...
tnx sa advice
I think eto prob nung akin... starts fine if not parked overnight unused... need to "prime" the pump by cycling the ignition to ON a couple of times before it starts.Originally Posted by espeago
