ser, patanong lang. do you sell K&N drop-in filter for trooper? how much does it cost? would you also know if it helps to reduce the "black" smoke? salamat in advance.
cj,
Si Auto_Xer ang nagbebenta ng K&N's dito sa board.Yung kay GlennSter pinabitbit niya sa mom niya straight from the US.
ooops!! sorry po! salamat ser OTEP. would you know how I can get in touch with Autoxer? salamat ulit.
Auto_Xer is Ferman Lao. Shop is Fusion R (724-3822) located at 1328 A E. Rodriguez Ave., QC
It won't help in the reduction of black smoke much kung:
1) Madumi na injectors mo
2) Wala sa tune-up ang makina mo
3) Mali timpla ng fuel injectors
4) Me singaw ang cylinders mo (valves or pistons).
5) Marami ng build-up ng carbon sa exhaust pipe mo.
Please have the other concerns checked first prior to your purchase ng K&N.
The filter will only make your vechicle breathe better (inhale more O2) and hopefully make the fuel/air mix be on stoich for the best combustion and thus (theoretically) emit lesser black smoke. But if the above mentioned items have been addressed.
my 2 cents.
IMm29, maraming salamat. well get in touch with Auto_xer!
wildthing, salamat din sa valuable inputs... definitely worth more than 2 cents =)
Otep, thank you for correcting the posted subject =)
