Results 1 to 9 of 9
    Oct 2009
    Mga sir ano ba size ng deep socket para sa 3 cylinder engine. Hindi kasi kasya un socket ng 4 cylinder na engine, hindi din kasya un pang motor. Para kasi may harang un pagpapasukan ng socket. Thanks.
    Common spark plug sockets are 21 and 16. Baka magnetic yung socket mo, nakaharang talaga yun.
    Kung gusto mo walang harang regular deep socket thin walled ang gamitin mo, 3/8 drive para maluwag kahit gumamit ka ng u-joint.
    Oct 2009
    Ang gamit ko na socket sir un t-shape na nabibili sa ace hardware, un kasi gamit ko sa iba kong sasakyan dito lang sa 3 cylinder hindi kasya. Thanks.
    Feb 2009
    Quote Originally Posted by eurostyle View Post
    3/4 inch-small engines e.g. Bush cutter and lawn mowers
    5/8 inch- hemi and newer engines
    13/16 inch-most older engines
    7/8 inch-WW II flat head engines
    Oct 2009
    So mga sir ang kailangan ko ay 3/8 drive deep socket na 3/4 ang sukat ng socket? Thanks.
    Mas ok siguro kung lagay mo yung spark plug number, eg. BKR6E NGK, ND, Bosch, Champion, etc or cross-reference mo nalang sa catalog, nandun yung socket size.
    Oct 2009
    Kakakuha ko pa lang kasi sir nito, papaltan ko sana spark plug, hindi ko nga lang matangal. Hehe. F8c 3 cylinder ito, may harang kasi un sparkplug, di kasya un gamit ko na T-sparkplug remover.
    I assume its same with f8b engine. Spark plug is NGK BPR5ES, 13/16 socket or 21mm.
    Better if you can post the pic, baka cap ung harang or baka thin-walled socket ang required tool.
    Feb 2009
    The modern car uses 5/8 inch spark plug socket for smaller and lighter spark plugs. Your generic universal spark plug socket is for 13/16 spark plugs. If it were tapered seat type, tighten 1/8 of a turn after the base makes contact(finger tight) and 2/3 to 3/4 turn if it is gasket type
Sparkplug socket
