Results 1 to 5 of 5
    May 2007
    hello mga sir
    ask ko lang kung ano kaya best motor oil para sa oto ko (toyota corolla gl '90model 16valve) kc first time ko plang papachange oil nung may ko kc nabili car e naka 5k kms n odometer nya..any suggestion mga sir? tnx
    Feb 2005
    i think any mineral based oil will do on your car since you will be doing it for every 5K kms.
    you can try the services offered by servitek for less than 1K (oil and oil filter package).
    Quote Originally Posted by zelenzo View Post
    hello mga sir
    yes. any mineral based oil will do.
    just make sure you regularly change oils by 5kms.
    Aug 2005
    mineral oil, 5K or 6months whichever comes first.. kahit sa shell lang. tapos wag mo na pagamitan ng flushing...
    pa check mo na din yung air filter, spark plugs, gearoil, timing para isahan na lang..
    kung walang oil leak ang engine mo try mo ang shell helix plus ok ito then sa next change oil mo shift ka sa shell helix ultra. mas tatahimik makina dito.
change oil help..
