Our newly repaired 4jx1 had a new problem kanina.
Diesel is dripping out of the tailpipe.
What's the culprit?
Mean A/F mixture?
Ano gagawin? reprogram the ECU?
Unichip upgrade?
The Cylinder Head, CH gasket and 4 injectors are newly replaced.
TIA.
What's the culprit?
Mean A/F mixture?
Unichip upgrade?
TIA.
with black or white smoke? any diagnostic trouble codes? bring it back sa gumawa for further diagnosis, 4jx1 is a very problematic engine esp the injectors kaya balik agad sa gumawa asap. check the oil level kung tumataas indication ng leak ng injectors o-rings.
It might still be the O-rings... if the job is still under warranty, you should have it checked again.
