Results 1 to 8 of 8
- Nov 2010
- 14
January 3rd, 2011 05:28 PM #1hello fellow tsikot fans! bakit kaya amoy gasoline ang engine oil ng oto ko,i noticed it when i wipe the oil dipstick, binuksan ko rin yung lagayan ng oil and tried na amuyin ayun smells gas nga.normal na amoy ba yun o nakakalito lang ang amoy ng oil at gas? so far wala naman problema yung car..hope matulungan nyo ako guys thanks
January 3rd, 2011 08:13 PM #2
Mag taka ka kung ang dipstick oil level mo tumataas every check up siguradong nadadagdagan ng gas yan
January 3rd, 2011 08:23 PM #3
Maaaring hindi masyadong nasusunog gasolina ng makina mo . Check mo kulay ng sparkplug kung ma carbon na itim ang kulay.
January 3rd, 2011 08:47 PM #4
yes you should keep a close eye on your oil level. pag nadagdagan yan overnight lumulusot na unburnt fuel in between the piston rings papunta sa oil pan.
January 3rd, 2011 10:23 PM #5
plus fuel may leak also into the crankcase via the fuel pump diaphragm.
January 3rd, 2011 10:50 PM #6
Minsan, misleading talaga amoy ng langis sa makina. Pero kung amoy gas talaga, pachange oil and filter mo muna, delikado sa makina kung may halong gas na.
Gasoline in engine oil can be caused by:
1. mixture not being burned properly which would suggest spark plugs, coils or cables,
2. signs of blow-by; worn-out rings,
as suggested by the others.
Best is to have a competent mechanic check on it though.
January 3rd, 2011 11:01 PM #7
+1 here
ano nga po yung oto?
when a fuel pump conks out(worn diaphragm) ... petrol will seep/mix into your engine oil via cylinder head/crank case... depends on engine's make.
visual sign of a dying pump(conventional pumps); meron parang drain tube usually yan , pag may oil leak na... time to replace the pump.
we replaced the fuel pump of my bro's former Feroza with that given symptom(oil leak).
- Jun 2010
- 76
January 5th, 2011 09:30 AM #8normal lang yun kasi gawa ng blow by gases kaya nagkakaron ng amoy gasolina.kung ang amoy ng gasoline sa muffler yun ang di maganda rich mixture yun air and fuel ratio..ang theoretical air and fuel ratio is 14.7is to 1..
ibig sabihin 14.7% ng air and 1% of gasoline..
sana ay makatulong sayu..service technician of lexus manila.ronald
Pangit ang fit ng taiwan replacement part. Medyo off ang clearances. Better bumili ka na lang ng...
