Results 1 to 13 of 13
    Aug 2006
    Tsikooters question lang po about calibration
    1.yung strada po namin 6 years na napansin ko po medyo lumalakas na sa diesel ibig sabihin po ba noon kailangan na i calibrate?
    2.kailangan na din po bang palitan ng fuel filter?
    3.pero yung strada po naman namin hindi naman masyadong gamitin.
    4.ok din po ba mag change oil every 3 months?
    5.ok lang po ba na nilalagyan ng crudo imbis na yung pang flushing fluid yung ginagamit pag nag change oil?
    6.give me some advice naman po kung ano magandang at cheap engine oil?
    7.yung ginagamit ko po pang change oil is castrol crb 5liters po tapos pang flushing yung rev-x
    pasensya na po kung medyo madami akong tanong sana po matulungan niyo ko dito sa question ko
    Sep 2006
    Quote Originally Posted by adventure View Post
    1.yung strada po namin 6 years na napansin ko po medyo lumalakas na sa diesel ibig sabihin po ba noon kailangan na i calibrate? Not necessarily. Check your air filter first as it may be restricted. If restricted, replace with original air filter from Mitsubishi. Insufficient air will result in less power and higher fuel consumption. If it does not improve, your injection pump may need calibration.
    2.kailangan na din po bang palitan ng fuel filter? Only you can answer this question. This depends on when you last changed it. Basically, a restricted fuel filter will allow less fuel to your engine, resulting in lower fuel consumption and low power output. Also, use original Mitsubishi filters.
    3.pero yung strada po naman namin hindi naman masyadong gamitin. What is your present ODO reading? Btw, recommended interval for timing belt change is 80k kms; this is a must.
    4.ok din po ba mag change oil every 3 months? I recall, change oil interval is every 5000kms or one year whichever comes first.
    5.ok lang po ba na nilalagyan ng crudo imbis na yung pang flushing fluid yung ginagamit pag nag change oil? Diesel fuel is not good for flushing your engine due to it's poor lubricating characteristics. It may do more damage than good to your engine. You don't really have to use flushing oil at all. Just change oil and oil filter; no need to flush.
    6.give me some advice naman po kung ano magandang at cheap engine oil? Use any oil (intended for diesels) from Caltex, Shell, or Petron. These are fine oils for your car, considering that your engine usage is not that harsh. I normally use Petron 15W-40.
    7.yung ginagamit ko po pang change oil is castrol crb 5liters po tapos pang flushing yung rev-x. See my reply on #s 5 & 6. I'm not familiar with Castrol crb.
    No problem. See my thread: "Diesel Fuel Injection Systems Help Desk" and pose your questions there. It will help you. Bye.
    Dieseldude
    Central Diesel/Service Mgr.
    1. Yes, not necessarily. Dinala namin yung MB100 sa Central Diesel Q.C. dati due to loss of power. Advise samin, change all filters and a lil nozzle cleaning. Naging ok naman after.
    2. Six years ka na bang hindi nagpapalit ng filter? hehehe. Click here for the 4d56 maintenance schedule (I know it's a scan from the Starex manual but the schedule is the same): http://tsikot.yehey.com/forums/showthread.php?t=31294
    3 and 4. See #2
    5. Ditto, just drain well (be patient, mag lunch ka muna or something while waiting). No need for any flushing or magic potion.
    6. Anything that meets your vehicle's required grade is ok. Check also if the oil is designed for turbocharged applications.
    7. AFAIK, Castrol CRB (the one in the green jug?) already exceeds the oil grade requirement of the 4d56 so it is suitable for use.
    Nov 2006
    mga sir, pwede po bng mlaman kng sn mganda magpacalibrate kc grabe kumain ng krudo pjero k 4m40 6km/lit, ty
    Sep 2006
    Quote Originally Posted by jtech_sns View Post
    4M40 uses a Bosch / Zexel diesel injection system. I recommend that you bring it to any authorized Bosch Diesel Service Center nearest your location, as these shops are factory trained, and have the necessary test equipment to do a good job.
    FYI, we are a Bosch Diesel Center (Central Diesel, Philippines)
    6km/liter city driving for a 4M40 2.8L intercooler turbo is not bad at all... My 4D56 turbo diesel consumes around the same for city driving too considering its just a 2.5L diesel engine...
    Nov 2006
    sn b yng diesel central pra mdala k pjero k? tnx s rply nyo mga sir!
    Sep 2006
    Central Diesel is located at 1176 Quezon Avenue corner Sct. Magbanua. Landmark is Capitol Madical Center. Building has a wrap around signage that says Bosch Diesel Center.
    me telephone number po ba kayo? open po ba kayo everyday and what time po kayo nag open sa morning. me problem po kasi toyota hilux surf namin me leakage ng oil sa me ilalim makina at me nakapagsabi sa husband ko sa bosch diesel center nga daw po dalhin. from san miguel bulacan pa po kasi manggaling husband kaya we want to know what time po kayo nag open at close para ma estimate namin time pagpunta dyan.
    thanks.
    Sep 2006
    Baka barado lang ang air filter. Check mo muna.
    Dapat mo palitan kung 6 years na ang fuel filter mo.
    Depende sa mileage mo.
    Hindi naman kailangan every three months, every 5000 kms. ang recommended.
    Hindi OK yan.
    Proper oil grade from Petron, Shell, or Caltex would be fine.
    Hindi ako familiar sa Castrol. Sundan mo lang ang oil grade na nakasulat sa Owner's Manual mo. Flushing is not necessary.
    No Problem..........
    Sep 2006
    Quote Originally Posted by perly_vien*yaho View Post
    thanks.
    Phones are 411-3711 to 13. Office hours are Monday to Saturday, 8am to 5pm. Oil or fuel leakage?
    besides sa low km/liter what other signs can u experience when it is time for a calibration
    Quote Originally Posted by jv2g View Post
    pag grabe na yong usok at mahina na ang makina. at napakalaking trabaho niyan, it might take up to 2-3 days depende sa bilis ng service, para kasing semi overhaul na ang mangyayari. if you dont see these things pa, then tune up lang yan.
Calibration Question
