Yung tsikot ko na honda lxi 1996, kapag nirerev eh prang my hika, kumbaga parang taong may asthma na kinakapos yung hininga. Tapos mahina din humatak. ano kaya problem nun?.... TIA
tama po yung tune up po muna
1 change spark plugs
2 change air filter
3 change fuel filter
4 change oil filter
5 change engine oil
kung na aadjust din ang valve clearance at timing ng lxi ipa-adjust mo na rin
Sir can you recommend a shop that can do complete tune up?
Location ko po is commonwealth Q.C.
Saan po ba ma recommend nyo? Thanks in advance.
And how much nga po pala usually and complete tune up?
Wala pang pang palit eh. heheh
Pina tune up ko na kasi yan weeks ago, tapos pinapalitan ko yung oil seal, sa crank tsaka sa taas(ano ulit twag dun?) kaya kinalas yung engine kasama yung timing belt, palagay ko hindi maganda pagkakabalik nung timing belt. o mali yung timing? pwede bang yun yung reason kaya humina hatak?
mali ang timing nyan bro.. what you can also do is to reset the ECU first and observe the results since kakapa tune up mo lang pala.
Could be that the station you load gas with has silently (and surely) implemented the 10% biofuel requirement. If this were the case try mo magpalit ng pinakakarga mong gasolina. With E10 implemented hihina nga hatak ng 96 mong Honda.
Try mo Gold ng Caltex. Petron XCS/Blaze. So far hindi pa implemented sa kanila.
Sad news e soon lahat E10 na. By July -Agust of 2010.
OT:Na try ko Extreme 97 ng SeaOil sa Mazda 323 '98. Humina nga hatak.![]()
