Results 1 to 18 of 18
    Sep 2011
    Mga bos, tatanong lang ako kc yung nissan boxtype 1989 nag ooverheat at ilan beses na rin tumirik, nun check ko my butas yun radiator kaya pinahinangan ko. Pina check ko s mekaniko ang sabi need n daw top overhaul(may tumatalsik n tubig pag inistart at hndi nakatakip yung rad cap). Ang quote sa akin 6.5k parts nd labor at 3.5k kung labor lang. Tama lang b pricing na binigay sa akin or overprice? Baka may alam kayo na mura and quality workmanship naman pa send po ng contact no. Preferable commonwealth qc yung location. Maramimg salamat
    Get first a proper compression test done before doing anything. Just because "tumatalsik yung tubig" it doesnt mean that may sira na.
    I also think it's way overpriced; get another mechanic. Best to buy your parts in Banawe as well (try Youngbros).
    Feb 2012
    kahit top overhaul nila yan kapag butas pa din un radiator masisira din, unahin nyo muna paayos un sa radiator then observe kung mag overheat pa
    Jan 2003
    might also be a faulty water pump.
    Sep 2011
    Quote Originally Posted by Ponkan View Post
    Sir napahinangan ko na yun butas s radiator pero same overheat pa din. Paano ko ba malaman kung palitin na yun radiator?
    Sep 2011
    Magkano kaya sir magpa compresion test?
    Sep 2011
    Quote Originally Posted by A121 View Post
    Any idea how much water pump?
    Feb 2012
    if sealed na un butas, try other option baka barado or may problema un higpitan sa ilalim baka dun tumatagas, baba nila un radiator mo mga nasa around P500 to, un fan nyo sir gumagana? walang leak un mga hose nya? waterpump siguro mga nasa 500 pataas un price, not sure lang if tama price ko
    Jan 2011
    yong sa akin, ganyan din. palit ng head gasket, ok na. i think its over priced.
    Sep 2011
    Quote Originally Posted by shelu View Post
    sir Mgkano nagastos mo s head gasket at labor? San shop ka nagpagawa bka malapit lang ako? Salamat
    Sep 2011
    Nababa na radiator at nahinang na un butas pero overheat pa rin. 5mins lng nananakbo ang taas kaagad ng temp then need ulit lagyan ng tubig yung radiator pero dun s water reservoir hind naman nababawasan.gumagana naman yun fan.
    Jan 2011
    di ko na natandaan kung magkano ang head gasket. 700 petot ata yon, im not so sure. ang labor 750 petot. kalahating araw din binanatan ng mekaniko. sa binilhan ko ng parts pinagawa. usually, sa tapat ng mga auto supply, may mga mekaniko. haggle is the name of the game.
    Sep 2011
    Bos san ka nagpagawa? Qc lang b?
    Sep 2006
    Head gasket na yan. Sandali lang gawin yan.
    Check also the water pump if it's not leaking; a tell tale sign of a bad water pump is continuously dripping water when the engine is running. If you need to replace it, GMB is an okay replacement.
    Mura lang head gasket; go for OEM if you can find.
    Sep 2011
    pansin ko kasi bilis magbawas ng tubig s radiator. Kahit puno na yun radiator while the engine is running pansin talaga na bumaba yun tubig dun s mouth ng radiator pero dun s water reservoir hindi naman nagbabwas. Magkano sir yun gmb na waterpump? Need ko ngayon ng mekaniko na hindi mataas singil at quality workmanship. Bka maya ma refer ka within comonwealth qc? Tnx
    Jan 2011
    madali lang magpalit ng head gasket. any shop can do it. just look for a reputable one. gas stations can do it.
    Apr 2008
    malamang cylinder head gasket, worse is cracked/ warped cylinder head
top overhaul nissan b12 engine
