Results 1 to 20 of 21
    Oct 2009
    What's the best and cleanest gas out there?
    Listen to my story...
    We have 4 vehicles...
    1. BMW R100 motorbike
    2. Civic Esi
    3. Lxi
    4. Mitsubishi lancer Glx 1991
    I don't use these vehicles frequently. They take turns depending on coding. Point is recently... I've been tanking in shell (Unleaded Gas). For some reason I felt like driving the mitsubishi more often for a month. Well guess what?
    I tried starting the 3 vehicles that have not been used for only 1 month. ALL the three of them.. Sabay sabay. Stuck ung valve. It only stays open and won't close anymore due to some sticky black thing that prevents the valves from moving. So.. I removed the head of each vehicle.. Popped the valves and cleaned them out with "firefly" (seemed to really dissolve the black stuff better than the brake cleaner). Put em back in with new head gasket of course and readjusted the valve clearances a bit. Then tada.. All the vehicles started to run properly.... Put em back aside.... Next morning all of em won't start again. I did a big mistake and didn't drained the Shell Gas. But how come only now!? This is the first time this happened!
    What are they putting in our gas these days? Is this because of the bio stuff and coconut essence or whatever that makes it this sticky? Did you guys have these problems as well?? I'd expect problems with the carburator but not on the valves!
    So here I am repeating the entire steps again. Not wanting to make the same mistake again. I'd like to know who has knowledge about local gas in the Philippines and what they mix in their soup. Obviously the gas today is worse than the gas we had 10 years ago. This unknown substance is able to pass through the fuel filter. It's really weird. *confused*
    All Shell gasolines now have E10 mixed into it. One major problem is the gasoline will "expire" within a few WEEKS when left in the tank of a car. This results in poor running engine. Only fix for this is to drain the fuel tank and replace with "fresh" gasoline.
    This is the exact same problem with my car. Since it is using Auto-LPG, the gasoline in the tank is not used up quickly, remaining in the tank of weeks to months.
    Since you mentioned you rarely use those cars, it might be advisable to look for gasoline stations that sell non-E10 mixed gasolines. Currently I use Petron XCS since it doesn't have E10 (yet). I suggest you to do the same for those cars you have mentioned that you don't use often.
    You might also want to read the following thread:
    E10 Ethanol and your engine [MERGED]
    http://tsikot.yehey.com/forums/showt...=59222&page=48
    Just back read it to the areas where it is useful for you.
    Aug 2004
    E10 isn't good for being stored long... (as GH has said) but if your valves got gummed up, it may also be that your oil got contaminated while the vehicles were in storage.
    Oct 2009
    Thanks for the info. This really helped build up my knowledge hehe. I figured the oil was sticky black and the gas was colored brown. Just drained it a few hours ago. This really sucks. I have now 70 Liters of stupid brown gas. Can't even use this #$%^ for making a BBQ grill. Sayang sa pera.
    I fixed my problem with a few tricks. Bought a gallon of firefly from the hardware shop and poured it all inside the spark plugs (no smoking of course) one after another. Removed the fuel injectors and cranked it. Amazingly the valves started to move again. This saved me time and headache to remove the damn head again. Now for change oil as well. Jesus headache talaga yung gas! We need a better fuel filter for this. It's scam.
    The firefly solvent works amazingly good in disolving carbon deposits.. Better than the commercial brake cleaners.
    Apr 2009
    Umm, mag-comment ako dito. My adventure is always "full tank" with E10 Unleaded Gas (Shell, Petron, Caltex) basta kung saan ko nalang gustong magpakarga. I use this car every friday only (coding car), so in short, naiimbak ang gas ko ng months.
    Anyway, pero kapag ginamit ko kasi ito, hataw mode talaga, I drive it hard, no baby-ing. Kayo po ba sir? Baka naman po kasi dahil soft driving yung "hinay-hinay", eh naiipon tuloy yung mga hindi dapat maipon.
    Jan 2008
    Ethanol Reformulated Gas does not like to be stored for long. Ethanol is hydrophobic, though it mixes very well with petrogasoline it tends to absorb water overtime making it heavier.
    Eventually it will settle into a different layer at the bottom of the tank, leaving a low octane gasoline at the top. Either layer will be very nasty to the engine.
    Once the water-laden ethanol is separated from petrol, there is no DIY procedure at the moment to restore it back. You have to drain your fuel system and pour a supply of fresh E10.
    Oct 2009
    Forget the E10. I would never buy it again. I just bought an imported LPG kit from italy. This should fix my fuel issues from now on..
    p_borj.. The civic is loaded... and I drive it hard.
    As for the R100 I drive it hard also.. Since this is a BMW.
    Hard means on the red line I guess.
    The only vehicle I don't drive hard is the Lxi and mitsu since it's carb and intended for family use only. On the mitsu the fuel pump also died.
    This E10 is really bad for my babies... If they go E10 all the way then it means LPG all the way for me. Not to mention I could use it for cooking pag sobra ako sa LPG hehehe Pwede na siguro mag install ng oven sa car lolz.
    Sep 2012
    Kulang ng F7... and Shift F7...
    Sent from my ASUS Zenfone 3 using Tapatalk
    Best gas? Of kors, yung libre (fleet card or gas card).
    Jul 2014
    Quote Originally Posted by jodski View Post
    Baka po cellphone ang ginamit, Sir 😁
    Sent from my SM-G7102 using Tsikot Forums mobile app
Best Gas?
