Results 1 to 17 of 17
    Dec 2012
    I was driving our van earlier today when I smell something burning. I flipped up the front seat and observed the engine and saw the alternator not turning. The fan belt sliding and burning. I brought the alternator to the shop and the bearing needs replacement so as the carbon stick inside.
    If this happens on a car, I probably wouldn't have noticed it until it breaks down. So I wonder what are the maintenance for the alternator? The carbon is inside so do i need to check that for a period of time and what will happen if it runs out of that carbon stick?
    Feb 2009
    Quote Originally Posted by madduck View Post
    alternators have about the same service life that of the starter on the average. it is five years or 100,000 miles. they don't usually need attention until you get paranoid about it. to make sure, have it checked every five years or serviced at around the 100k mile mark
    Jan 2010
    I am not 100% sure, but I have seen so many dismantled alternator units in the past and they are constructed similar to a 3 phase generator, meaning, it doesn't have a carbon brush that needs to be replaced... maybe it's just a stuck up or faulty bearing.
    Usually, its the bearing, IC voltage regulator and the rectifier which sometime fail.
    In your van's case, maybe its just really a faulty bearing....
    Jan 2010
    Our car's starter motor is a DC motor, it has a carbon brush or carbon stick that the TS have mentioned....
    Feb 2009
    Quote Originally Posted by rmsoriano View Post
    the pair of carbon brushes are the only means of connecting the rotating field coil to the power source, the voltage regulator and the ground. over time, they wear out as a result of constant friction between the slip rings and the brushes. if the rotor is stuck, usually it is the bearing or in some cases rust building up between the claw poles of the rotor and the stator laminated core.
    Jan 2010
    yes sir, that's why i am not 100% sure, but there are design that also uses carbon brushes, these are those tha does not have permanent magnet in the rotating field.
    Feb 2009
    if you have a permanent magnet rotating field coil, how do you regulate voltage from a constantly changing rotational speed of the car's engine?
    Jan 2010
    I am sorry sir, but earlier I was thinking of a brush-less alternator.. I know that it is possible to have a regulated voltage output in a brushless alternator. and yes, maybe it is not from a permanent magnet....
    Feb 2009
    no need to apologize. no harm done. but so far, all the alternators i worked on from bosch, nippon denso, motorcraft, mitsubishi, delco remy, delco, hitachi and other automotive alternators all have carbon brushes except the motor/regenerative alternator of the toyota prius
    Jul 2010
    There's no way that a carbon brush will stop rotation of armature of alternator. Carbon brush was enclosed in a metal casing and can not able to dislodge to cause obstruction.
    Feb 2009
    Quote Originally Posted by Chinoi View Post
    sir, there are no alternators equipped with armatures. motors do. the rotor or rotating field coil's slip rings does not indeed stop rotation of the rotor or field coil and is not strong enough to stop rotation, it will snap. the carbon brushes are never enclosed in metal casing or a severe short circuit happens.
    Oct 2011
    mahirap din alternator maintenance considering the location. you will have to remove some of the components inside the engine e.g. coolant reservoir and of of course the fan belt before you could remove the alternator.
    Feb 2009
    car maintenance is not only a technology but is also an art form. the cleaner you keep yourself and keep yourself free from knicks, cuts, bruises burns the more skilled you are in addition to properly diagnosing and repairing the car. if it is too difficult at first, try it again and again until you get proficient
    Oct 2011
    correct sir. just removing the belt and installing it after is already a tough task.
    some alternators are easily removed from underneath the car
    i think the poster meant the brasslike sleeve holding the carbon brushes which are electrically isolated from each other and from the grounded casing
    Oct 2011
    but still you have to remove the fan belt first. haven't seen removing alternator underneath the vehicle mukhang mas mahirap un.
    Dec 2012
    ahh good to know. so it was only a bad day and the bearing broke. thanks for the info sir!
Alternator maintenance
