Results 1 to 10 of 17
- Sep 2013
- 153
October 15th, 2013 05:13 PM #1Hello,
Would just like to ask if there is a compatible air intake for Honda PH16 engines?
- Sep 2013
- 153
- May 2012
- 372
October 27th, 2013 03:03 PM #3Ph16 po ba or ph15? Vti and lxi?
To answer if you need to replace the stock air intake of your lxi with ph15 engine, try to buy those knn or simota air filter element or cone filter, combine with air intake tube. Same with the vti with ph16 engine.
As far as i know, there will be a difference in the intake tube to be used in lxi vs vti.
Sent from my iPod touch using Tapatalk - now Free
- Sep 2013
- 153
October 27th, 2013 08:57 PM #4Ph15 LXI siya. parang ung filter kasi ng Ph15 near dun sa carburator mismo. Ung nakikita ko kasing air intakes para may aluminum na part na iaatach dun sa carburator. Kasama na ba un sa air intake tube?
- Sep 2013
- 153
October 29th, 2013 06:47 PM #5http://www.google.com.ph/imgres?sa=X....2105712890625
Parang ganyan kasi ung engine ko. Pede bang papalitan ung air intake? Ung kulay black na plastic.
- May 2012
- 372
October 30th, 2013 12:07 AM #6http://m.sulit.com.ph/index.php/view...l+SiR+body+m/t
Hiram lang po yung pic.
If you want to change to racing or cone filter with air intake piping, the stock airbox assembly will be replaced.
Sabihan mo lang sa shop ma bibilhan mo na pang lxi civic ek. The air filter and the air intake piping usually come in a package.
- Sep 2013
- 153
October 30th, 2013 06:37 PM #7
- Sep 2013
- 153
November 1st, 2013 04:37 PM #8Found this article about swapping intake manifolds My y7 to y8 Intake Manifold Swap (pics) - D-series.org
Meron na kayang nagawa dito nito? Actually, ang goal ko sana kung mapagawa ko sa Civic 97 ko to e para mapalitan ng short RAM intake saka malagyan ng strutbar.
- Sep 2013
- 153
November 6th, 2013 01:53 PM #10
share ko lang yun sabi sa akin ng suking mekaniko ko ah.
magaling yun kaya naniniwala ako sa kanya
tinanong ko lang kung pag maglagay ako ng simota sa honda ek lxi ko
pano gagawin ko sabi nya di daw tinatanggal box na itim ng air intake mas malakas hatak
mas maganda daw kapag may box pa din mas effective.. kung like mo bumili ng air intake
meron naman yan sabihin mo lang honda ek lxi na simota.
wag rekta ^
VinFast VF 3
