Results 1 to 5 of 5
- Oct 2003
- 176
November 8th, 2013 11:10 AM #1Sir/Mam,
First gen Mitsu Outy 2.4 Gas.
Patulong lang po.
I am having a hard time searching for a reputable shop in Banawe.
Do you know a shop/talyer where i can have MAF sensor check/reset?
I already change the Fuel filter, Fuel Pump, clean throttle
Problem:
the car is normal when driving. Problem: Engine dies when fast flooring the gas pedal
Thanks in advance
- Aug 2008
- 405
November 8th, 2013 11:12 PM #2Have you tried resetting the ecu? Disconnect the battery for about 30 secs then reconnect. Baka may fault lang. But this is just a guess...
November 9th, 2013 02:51 AM #3
Namamatay ba kahit neutral then floor the gas? If yes, baka injector ang problem. Mahirap kasi pinpoint yung problem Pero 80% sure ako na fuel ang problem.
- Oct 2003
- 176
November 9th, 2013 08:33 AM #4*rac98
i will try doing your suggestion sir.
*[archie]
hindi sya namamatay kapag neutral sir. sa pakiramdam ko kapag malapit ng mamatay makina dahil sa mabilis na pag apak ng gas ay linalagay ko sa neutral para mabuhay lalo yung makina.
- Apr 2009
- 429
November 10th, 2013 07:58 AM #5just clean first your MAF sensor with electronic contact cleaner. It is also wise to clean or replace your air filter with OEM...
Update pala nito, madali lang nya na dispatch Innova Zenix Hybrid nila. They are now using Tesla...
2023 Toyota Innova (3rd Gen)
