Results 1 to 10 of 12
- Nov 2008
- 24
July 30th, 2009 05:46 PM #1mga bossing, car ko po ay corolla xe, the problem is hindi na gumagana ang plunger para sa idle ng aircon kaya kung bukas ang aircon, ang baba ng idle and pag ng-automatic naman ay wild ang idle.
my querry is magkanu po ba ang surplus na carburador and kung may repair kit, magkanu po and saan nakakabili? and lastly, pwede po ba carburador ng 4k sa 2e? salamat po sa inyo!!!
- Jan 2005
- 445
July 31st, 2009 07:20 PM #3I don't think sa carb ang problema mo, pag nagmemenor yan walang problema yan. Ang problema mo ung sa idle up vacuum. sa aircon repair mo dalhin.
July 31st, 2009 08:38 PM #4
[SIZE=4]Tama si Reym, hindi carburador problema mo.
Yung "idle up vacuum" ang me sira, not the carburetor.
Yung "idle up vacuum" ang device to maintain a constant idling rpm in the event na sumipa ang load ng compressor or other load sa makina.
Dalin mo lang sa trusted mechanic mo. Baka yung linya lang me dumi or what.
[/SIZE]
July 31st, 2009 11:35 PM #5
odrag,
your engine is way too small for your car as designed for the asian market, this is the reason why the idle speed drops with the additional airconditioning load to the engine and the electrical system when the compressor clutch and condenser fans kick in. to compensate this, the fuel control either raises the idle speed by the use of a vacuum throttle kicker or an idle up solenoid to open the throttle plate higher than idle speed (carbureted engine like what you have). this solenoid throttle kicker is in parallel circuit with the compressor clutch.
jick
- Nov 2008
- 24
August 3rd, 2009 05:33 PM #6mga bossing, thanks with all the inputs! hindi nga carb ang problem, the culprit is my "idle-up plunger". ng-bara po yung butas kaya di humihigop, nalinis ko na and nagpalit din ako accuator. working na po, meaning nag-lalaro na po yung mechanism attatched to it kaya lang baligtad pa rin ang idle, bumabagsak kung bukas aircon and wild ang idle kung ng-automatic na. ano pa kaya ang problema? pasensya na po pero sana matulungan nyo pa ako...
- Jul 2009
- 23
August 3rd, 2009 07:55 PM #7bro adjust mo idle up adjusting screw habang nakabukas aircon para makuha mo ang tamang idle.. at palitan mo ang vacuum hose baka may bara na hindi mo natanggal o kaya lumiit na ang butas ng hose mo.. hindi kasi pwede kapag maliit ang butas talagang magwawild yan..
- Jan 2005
- 445
August 5th, 2009 12:39 PM #8Alin d2 ang hindi gumagana? Ung isa sa 2 bilog?http://cens.com/cens/supplier/16337/.../54211/BIG.jpg Alam ko pede yan, pero tingnan mo muna mabuti baka same problem lang ang abutin mo, kc normal sa 4k carb na luma ala na provision para sa aircon.
I suggest check mo muna mabuti, kung ung 2 ang sira nakakabili sa surplusan nun.
Check mo kung kasya ung 4k sa slot, pag kasya pwede.
- Jun 2014
- 21
June 9th, 2014 04:42 PM #9Yung car ko is oldlook 91, yung carb nya ay pang 4k engine na nung mabili ko. Problem is walang idle up para sa aircon kaya pag nag aircon ako bumababa ang RPM. Ginagawa ko tinataas ko ng konti para pag ang aircon ok pa rin. Good thing is matipid sya sa gas pag naka AC at magastos pag off ang AC. Bagong bago yung carb ko pa pang 4k. I've heard na yung mga luma walang sabitan ng AC idle up pero yung sa kin wala rin.
Meron bang nabibili or nakoconvert na AC idle up para magfit sa 4k na carb? Sana may sumagot sa tanung ko mga bros.
- Sep 2019
- 8
September 2nd, 2019 08:39 PM #10Sorry for bumping this old thread,
I had to since I am unable to start my own thread yet.
so I have a Ae92 corolla small body with a 2e engine, yong problema po sira na ang carborator, so bumili ako sa Lazada ng 4k carborator kasi sabi ng seller na pwede lang, tapos nong dinala ko sa mekaniko po, sinabehan ako na wala daw idling sa aircon,,
pwede po pa advice mga sir,
AE92 toyota corlla, small body, 1989, 2e engine po pala
VinFast VF 3
