Results 1 to 10 of 16
- May 2005
- 82
March 6th, 2016 04:24 PM #1
- May 2005
- 82
March 6th, 2016 06:03 PM #2Just found the specs for the 4AFE ignition coil.
Ignition Coil
5. INSPECT PRIMARY COIL RESISTANCE
Using an ohmmeter, measure the resistance between
positive (+) and negative (–) terminals.
Primary coil resistance (Cold):
1.1 ~ 1.7 at –10 ~ +40°C (14 ~ 104°F)
If the resistance is not as specified, replace the ignition
coil.
6. INSPECT SECONDARY COIL RESISTANCE
Using an ohmmeter, measure the resistance between the
positive (+) and high–tension terminals.
Secondary coil resistance (Cold):
9 ~ 15 k at –10 ~ +40°C (14 ~ 104°F)
If the resistance is not as specified, replace the ignition coil.
Thanks!
March 7th, 2016 06:50 AM #3
VinFast VF 3
