I have an Altis 2003 ride 1.6G automatic. Sometimes i noticed intermittent (on and off ) abnormal sounds coming from the engine or maybe maybe transmission
Initial troubleshooting done:
1. Off air con (still have)
2. Switch to park or neutral (still have)
3. Car is parked (yesterday) still occurred for ten to twenty seconds tapos nawala na.
3. Check oil (oil level is high based on the dipstick but still within limits)
*(Change oil was done 3 weeks ago)
Details:
1. Sound is like the engine or something works harder for ten to twenty seconds tapos mawawala na.
Intermittent problem. AFter the abnormal noise it turns back to normal (normal humming engine noise). I noticed this more on idle to low speeds (since noise is a lot less) than driving in a highway.
My moms car(2003 altis 1.6 e)has the same problem before.you can simply check (DIY)it by removing the drive belt.using 17" wrench.after removing the belt.try to start the engine for a few seconds.if the unusual engine noise is gone,maybe the sound is coming from the tensioner bearing or the alternator.
