Results 1 to 12 of 12
    Hello Sir(s)/Ma'am(s),
    Magtatanong lang po kung anong auto repair shop marerecommend nyo na knowledgeable sa SR20DE na engine? i'm from taytay and no one seems to know how to repair/proper engine checking dito sa area namin... lagi na lang sinasabi palitan makina kasi mahirap kumuha pyesa / di nila kabisado / etc. etc. (>.< tsk..).
    I love my altima and my SR20DE powerplant... ayoko naman sa casa hanggang maari kasi taga ang labor at pyesa nila saka di nila pinapayagan sumama yung owner kapag gagawin yung auto...
    Best Regards and Thanks in advance.
    ano ba problema sir ng makena nyo? ang layo nyo kasi sir.
    hahah! yeah, malaking problema is yung erratic idling, and namamatayan na ako minsan on the road. kakapalinis ko pa lang last month ng throttle body at maf. yun pating idle screw ko destroyed na needs replacement, wala somewhere here sa rizal ang meron. (most likely i needed to go to banawe for that...). takot mga mekaniko gumalaw dito ng SR20 eh. hahaha. baka daw masira pa nila lalo di daw nila alam kasi.
    Quote Originally Posted by Haruto View Post
    na try mo na bang linisin distributor mo sir? check mo din heat sensor mo baka sira na? yan lng muna check mo dis connect mo lng heat sensor mo pag nag bago at gumanda idling mo yun ang sira...linisin mo din distributor mo. yan lng muna ang mga check mo!
    Try ATA in pasig or Streetspecs in Banawe bro.
    you can try contacting these shops:
    SPEEDLAB http://www.speedlab.com.ph/contact.php
    SPEEDYFIX http://www.speedyfixph.com/
    Jun 2009
    In case you need a MAF sensor for the engine, I have a surplus stock for SR 20DE engine. Text me at 0927-2807334.
    Oks thanks po sa mga recommendations.
    *nickriingen: Oks pa naman daw yung MAF ko sabi nung nagpalinis ako sa casa eh. pero i'll save your number just in case ^^,m
    Jun 2005
    Altima with an SR20DE din ang project car ko... actually, car ni GF yun.
    nasira ang Fuel Injector nun, so i had to replace it with surplus. 800 lang yun. mahirap talaga maghanap ng parts ng altima. kalimitan order pa at sobra mahal! 20k na din nagastos ko sa altima project ko pero sobrang tipid mode na. eto mga napalitan ko na:
    valve cover gasket
    front and rear brake pads
    reface brake rotors
    change injector
    suspension c/o zee
    engine support c/o m7
    clutch master and slave
    anyway, you can check you Throttle body and possibly have it cleaned. as for parts, hanap ka sa youngbros sa banawe. dont tell them na altima ang kotse kasi di niila alam yun. you can try saying "bluebird" or SR20 na engine. btw, wala ka din makukuha na distributor cap and engine support nyan...
    *sirkosero
    Thanks sa info sir! talaga 800 lang injectors? sa young bros yun? kasi nung nag papalit ako ng isang injector sa may local shop namin dito sa taytay, sabi niya kumuha daw cia sa banawe at ang presyo nya sakin 2k!!! engine supports and distributor cap oks pa wala pang 1 year pareho.
    Salamat talaga sir sa info. ^^,m
    Dec 2008
    This might help...
    I keep a copy of my engine repair manual in *******.
    Note the manual is for various versions of GA16 and SR20 engines as used in the Nissan Sentra/Pulsar. I hope the SR20 sections will be of help to you. It includes diagnostic procedures, with or without the use of the onboard ECCS module.
    Below are the links:
    Part 1: Engine Manual (about 70MB)
    http://www.*******.com/dl/33353366/b...-DDG-.pdf.html
    Part 2: Service manual for transmission, aircon, brakes, etc. (about 220MB)
    http://www.*******.com/dl/33370664/f...-DDG-.pdf.html
    There should be no problem downloading from *******. You can login as a "guest", but the download will be slower.
    Jun 2005
    sa evangelista ako bumili ng injector pero pareho lang price sa surplus sa banawe... u might want to consider buying parts sa binondo. hirap kasi talaga pyesa kailangan pa ng sample
SR20DE engine knowledgeable autorepair shop?
