Pwede po ba yung hindi turbo charged na makina lagyan natin ng Intercooler? Ano po ang magiging effect nun pag wala ang turbo? Lalakas ba sha o hihina lalo?
hindi naman hihina... pero para saan? bakit ka maglalagay kung hindi naman kailangan... saka mo na ipalagay kung naka-turbo... pwede rin yan para hindi pwersado or mag-init masyado... pero hindi ko lang alam kung lalakas yun hatak, pero siguro naman kahit papaano may effect yan![]()
actually adding an intercooler without a turbo will result in less power output from the engine. Its because the intercooler will act like an air restrictor (because of the numerous small passages thru the intercooler).
Also the intercooler is an air to air heat exchange device (usually). So if the outside air and the intake air has the same temperature, there will be no heat exchange to happen.
based on your question, I think you are trying to get cooler air into your intake which should result in more power.Originally posted by Panzer
The best way to get cooler air is to have a cold air intake installed. You can either buy one or make one yourself.
Cold Air Intakes or CAI usually consists of an air filter located outside the engine bay and is connected to the engine intake via a long pipe.
Yah... for a diesel, a snorkel would be better... it would result in a slightly slower air charge, but much cooler air.
The main function of the intercooler is to make the air COLDER which results in more compact air w/c means more air molecules coming in the ENGINE making your fuel burn better and faster. BUT! you must make your intake free flowing OR as you may see sa other cars, they put their air intake sa front ng cars sometimes sa headlight to force the air in the intercoolers located behind the bumpers. Mas cheaper option yun Snorkel, around 12t lang compared to intercoolers w/c costs 50 to 70T. Good Luck
