Results 1 to 11 of 11
    Oct 2008
    Pag umabot na ba sa 14.92volts ang charge nang alternator sa battery, eh overcharging na ba ito? Corolla Liftback kotse ko at ang alternator nito yung old model, meron pag external voltage regulator
    Oct 2011
    Quote Originally Posted by viraccat View Post
    Sir accurate/calibrated ba ung volt tester mo?
    Jul 2006
    Your voltage regulator is already faulty. Continued overcharging like that will eventually fry your battery. Update your alternator.
    Feb 2009
    what year, what engine does your corolla have? some toyota cars' charging voltage reach as high as 15.1 volts specified by the factory. if your battery is not overheated nor losing too much water, it should be okay
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    Jul 2011
    What is the ideal voltage for 2sn battery during charging (no aircon on) and after start-up?
    Oct 2008
    my car is '81 model. Alternator capacity is probably 40amps. Engine is 2T, 1600. Tester gamit ko is digital from crd-king
    normal charging voltages for a lead acid battery is minimum 13.2 volts (slow charge) and maximum 14.7 volts (fast charge). actual maximum where the battery starts to get damaged is 15.6 volts.
    so yes, medyo mataas na yang 14.92V. need mo na mag-add ng water nyan twice a week siguro.
    - - - Updated - - -
    Feb 2009
    if your voltage regulator is that of the external electromechanical type and not the solid state electronic, it might need adjustment or if the tension springs are weak or rusted, it will have to be replaced.
    Oct 2008
    Salamat sa lahat nang nagshare. Balak ko palitan alternator nang ic type. In the mean time, siguro on ko na lang park at day time para may load. Thanks again sa lahat
    I suggest you turn on your accessories,- aircon, headlights or foglamps (DRL style if during the day... ), and radio (to a much lesser extent) to "regulate" the voltage across your battery, bro... IMO, okay lang iyan if you do these things...
    My "old school" van's alternator is at 14.5V max at no load, and its battery is now 3 years and counting...
    17.7K:santas:
    Oct 2009
    marang mataas yan a better have an electrician to look at it.
14.92 Volts
