View Poll Results: What is the Longest Life of your Battery?
- Voters
- 90. You may not vote on this poll
less than 2 yrs
4 4.44% -
2 years
20 22.22% -
3 years
20 22.22% -
4 years
24 26.67% -
5 yrs and over
22 24.44%
Results 391 to 400 of 552
February 22nd, 2022 04:29 PM #391
April 2nd, 2022 02:29 PM #392
- Jan 2008
- 4,726
April 2nd, 2022 05:17 PM #393
April 2nd, 2022 08:29 PM #394
Well, post warranty, I always remove the seal sticker on 'maintenance-free' batts to periodically top up when needed. This + a smart trickle charger are proven ways to extend batt life.
Sent from my SM-G970F using Tsikot Forums mobile app
April 2nd, 2022 10:04 PM #395
amaron go 1sn going 3 years this month hehehe
kaka topup lang ng distilled water (2nd time already)
Sent from my M2012K11AG using Tsikot Forums mobile app
- Feb 2014
- 2,711
April 2nd, 2022 11:33 PM #396just topped up my yuasa "low maintenance" w/ distilled water. then did overnight equalization at 15.0v. then checked each cell w/ a hydrometer. there's some small imbalance so i did 15.4v for a few hours.
it's also hooked up to a float charger when parked.
let's see how long it lastsprobably well over 5yrs. the most common failure is when one cell gets a bit lower than the other cells which leads to sulfation in that one cell. one bad cell and the whole battery is junk
so in case anyone's wondering the 15v equalization charge is intentional overcharge. the full cells just boil off the overcharge to allow the low cells to charge up. a rather crude method to equalize the cells
- Jun 2005
- 3,774
April 2nd, 2022 11:49 PM #397Ingat lang dyan. Last february ganyan bibilhin ko sa suki ko din sa makati. Apparently may tubig na talaga siyang halo at di tulad ng sa motolite na lalagyan lang nila ng acid+water pag binili mo na.
Ang ending, nung nilagay sa kotse, dead batt. Ayaw magstart. kailangan pa daw charge muna. Sent from my MI MAX 2 using Tsikot Forums mobile app
April 3rd, 2022 03:11 PM #398
2 years and 9 months yung Varta, 1st time ko magpalit ng battery.. Amaron din yung pinalit ko..
April 3rd, 2022 06:49 PM #399
More than 4 years na yung Amaron HiLife sa XT ko. Month to month ko naman check if it’s failing.
April 4th, 2022 03:20 PM #400
Cooling system is sealed so atmospheric pressure shouldn't be affecting internal pressure. But...
