Results 1 to 5 of 5
    Apr 2008
    just trying to help 2 friends with problematic power mirrors...di na kasi inasikaso pero baka maayos ko pa
    I just need to know paano alisin yung salamin ng side-mirrors so I can get to the motors to spray WD40. vehicles are vios 2005 and lancer 2009. I know how to remove the assembly sa body but not the mirrors, screwdriver lang yata kailangan ko?
    wala kasi ako kilala tirador ng side-mirror kaya wala ako matanungan :P
    Why don't you just use the straw provided with the WD 40 and fire behind the lens?
    To take off the side mirror just pry it out with a spoon or similar blunt instrument. It will pop out of its socket and into your hand.
    Nov 2006
    I heard some people uses a heat gun to heat the mirror slowly so it can be removed easily before prying it.
    pwede ba wd40 dito kasi pagkaka alam ko ang motor na ito ay screw type at ang gear ay made of hard plastic, kasi nakita ko na yung sa civic na noong sumabit ang sidemirror . hati ito kaya labas lahat
    Pwede naman. Blind shot lang. Ganun ginawa ko dati dun sa stuck up na side mirror, pinaliguan ko ng WD yung likod ng salamin while another person, operates the power mirror motor from the driver's seat. After a while, gumalaw na.
paano alisin salamin ng side-mirror?
