Results 1 to 3 of 3
    Feb 2012
    After ko start pickup ko..bigla nlng ayaw gumana ng signal lights ko..pero 2 weeks ago the last time I use my pickup ok pa naman..the lights naman are just new was bought a month ago...san po kaya problema? baka pwd ninyo explain para D.I.Y nlng po...para less gastos if ever kaya naman..salamat..
    1994 Mitsubishi L200 po ulit car ko
    Aug 2010
    Check first if fuse is blown if it is, a short may cause it, if not loose wires or connectors considering the year model. Defective flasher relay can also be check if both hazard and signal wont work
    Jan 2012
    check mo din signal flasher mo.
1994 Mitsu L200 Signal Lights
