Results 1 to 7 of 7
    mga tsikoters bka pede patulong dito sa 99 nissan frontier 4x2 AT,
    ung digital instrumental panel nagloko biglang ng- 999999KM ang odometer tapos ang temperature gauge went high and ang fuel gauge went to high din! pero ngbabalik din sa normal. pls help!!
    May 2007
    May problema ang instrument cluster mo. See this related problem of your's.
    1998-1999 Nissan Frontier - Symptoms: Gauges not working or intermittent. Odometer reads 999999. Repair Cost $199
    ...I just wanted to thank you for the great service & quick turn around time on my 1998 Nissan frontier cluster. I had sent this to an electronics repair shop in the south. They had my unit for over 2 months & told me they could not obtain parts, however you were able to repair in 24 hrs.
    Its a pleasure to do business with a competent & honest person.
    [SIZE=2]K.Smith - Dubuque, IA[/SIZE]
    yung cluster mo ay may SELF DIAGNOSTIC SYSTEM , and it can be checked by a qualified automotive electronic technician however, pag masusundan mo 'to this is the procedure ;
    ON BOARD DIAGNOSTIC MODE:
    1) to activate on-board diagnostic mode,turn ignition ON. change ODOMETER/TRIPMETER TO " TRIP A " or "TRIP B". turn ignition OFF.
    2) while pressing ODOMETER/ TRIPMETER SWITCH, turn ignition ON . Ensure TRIPMETER indicates "000.0" press ODOMETER/TRIPMETER switch more than 3 times within 5 seconds.
    3)On -board diagnostics mode is activated. All ODOMETER/ TRIPMETER segments should be illuminated. REPLACE SPEEDOMETER ( UNIFIED METER CONTROL UNIT ) if operation is not specified.
    4) press and hold ODOMETER/TRIPMETER switch . gauge indicators will move and become stable after about one minute .
    basically what it says here is 90 % of the trouble is coming from speedometer or UNIFIED METER CONTROL UNIT.
    v6dreamer thanks very much!
    bambino thanks for the post, ask ko lang po if nagawa ko ung ON BOard DIAGNOSTIC MODE, maaayos po ba siya nuun? PAsensya medyo bago bago lang po sa mga ganitong problem. THANKS AGAIN!
    yung info para lang malaman kung alin ang faulty . you could ask your trusted mechanic to interpret it for you .
    don't forget to ask them to check the cluster wires i.e. ignition power and ground
    thanks very much again mr bambino!
digital instrumental panel need HELP!
