Results 1 to 6 of 6
- Jul 2009
- 2,618
September 22nd, 2021 05:26 PM #1I just bought a Greddy (copy) tachometer. balak ko ilagay sa l300 fb with 4N14 engine. iisa lang naman yung signal wire. ang question ko lang saan ba exactly sa alternator dapat i-tap? thanks
- Jul 2009
- 2,618
November 14th, 2021 01:36 PM #2okay ako na din sasagot sa tanong ko after mabutinting. walang tachometer signal provision ang l300 fb with 4N14. maski obd di mabasa. 5 lang ang may live connection sa pinout niya. maski alternator wala. naisip ko only way is to break the alternator open and solder a "w" terminal to one of the poles inside. i was not willing to do that dahil relatively bago pa yun l300 and still under warranty. boost gauge na lang subukas ko lagyan. hihihi
- Jan 2008
- 4,726
- Jul 2009
- 2,618
November 15th, 2021 11:48 AM #4
- Jul 2009
- 2,618
- Dec 2023
- 11
December 30th, 2023 05:09 AM #6Sure thing! When installing your Greddy (copy) tachometer on your L300 FB with a 4N14 engine, you'll want to tap into the alternator's signal wire. Locate the alternator, and look for a single wire that carries the RPM signal. Tap into that wire for your tachometer connection. It's typically a thin wire coming out of the alternator, and you should be good to go once you've made that connection. Easy peasy! If you run into any issues, feel free to reach out. Happy modding!
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
