Results 1 to 4 of 4
    Jun 2009
    mga sir.. may problema po ako sa civic 02 ko.. hope anyone can help me.. kasi po.. i bought this second hand car (civic 02) na may nakainstall na APEXI V-AFC.. as told me by the seller na nakakatipid daw ng gas. so its included in the package but then, nadisconnect daw niya ata yung mga wirings kaya hindi gumagana at that time na tinest run ko. pero he guaranteed me na in good running condition pa ito, so i trusted him.
    then one time nalubog sa baha yung kotche ko, badrip sobra pero ayun.. natuwa naman ako dahil biglang gumana yung APEXI..hehe lumabas sa display yung dalawang digital meter.. pero bigla din nawala after a day na gumana sha. so lalo ako nacurious.
    so last sunday, nagfeeling mekaniko ako, i followed the wirings from the APEXI unit then nakita ko yung connections niya sa ibaba ng manibela, so ginalaw ko yun.. knowing some basic sa pagiging electrician.. hehe i removed all the electrical tape na naglalagkit na.. and at first i figure out kung panu mapagana yung APEXI.. naloose lang pala yung mga connections nung wire.. so binalik ko lang... happy that i am na gumagana na.. while i was putting the new electrical tape back.. biglang nawala yung display ulit sa APEXI ko.. at worst ayaw na magstart nung kotche... waaaahhh...
    so i called an home service mekaniko since matic yung kothce hindi pwede itulak.. (cost me P500!) grabe taga! tpos fuse lang pala yung nasira.. so gumagana na yung kotche.. kamalasan nga naman.. pagalis nung mekaniko.. napansin ko na umaandar nga yung kotche.. pero nakailaw naman yung parang orange sa dash.. yung led sa baba ng oil led ata yun.. HEATER ata yun led na yun..
    mga sir.. anu na kaya problema nung kotche ko na?? help pls.. cause kaya ito nung APEXI? kasi po pag ginaground ko yung connections ng APEXI.. parang namamatayan ng makina.. hope anyone can help me with this matter.. thank you in advance... parang mamumulubi nadin kasi ako pag dinala ko pa sa mekaniko..
    Jun 2009
    add ko nadin pala sir, kung panu po ba gamitin ng tama yung APEXI V-AFC vtec airflow converter?? hindi ko din po kasi alam kung anu yung tamang units ang dapat ilagay dun.. thanks ulit..
    APEXI V-AFC function is to adjust the air-fuel ratio to get better power or economy. The settings differ from low and high throttle setting.
    Adjusting the settings in the AFC blindly will not result in anything positive. You will need to use a dyno to have it set properly. Currently there are three shops with dynos you can hire to tune your AFC. Tuning time on the dyno costs around P5000 per hour.
    The three shops with a dyno are:
    Auto-Plus
    Speedlab
    Autotechnika
    [SIZE="4"]MODERATOR's NOTE:
    *majinbu
    When posting, do not post in a run-on sentence and single massive paragraph. Cut it into proper sentences. Do not just use "..." between phrases.
    Why?
    It makes you posted message(s) easier to read by people. And if more people read your post, more people can help you.
    [/SIZE]
NEED HELP, regarding electrical. [APEXI V-AFC, etc]
