Results 1 to 11 of 11
    Feb 2013
    Hello mga katsikot,ang problema ko po ay bakit mabilis bumaba ang fuel gauge sasakyan ko pag mababa na sa 1/4.liteace diesel 2cturbo sasakyan ko.pag fulltank okay naman hanngan g pag nasa 1/4 na mabilis bumababa sa empty o umiilaw na kulay orange sa dashboard lalo pag medyu palusong.pag paakyat okay naman.nang umilaw na ung`emty sinubokan ko idrain ung natira sa tangke at halos 10liters pa laman.okay ba ito?ano kaya naging dahilan kasi hindi naman dati ganito.salamat sa may input dito.god bless
    Oct 2011
    Sir, ung sa shape kasi ng fuel tank. kaya pag 1/4 na mabilis na maubos.
    lapit na february 25, edsa revolution. punta ka dun sa ortigas malalaman mo na... hindi ka nagiisa!
    lahat tayo ganyan, pag mababa na sa 1/4 mabilis na bumaba ang gauge.
    Feb 2013
    hello,kung ganun okay lang pala un na pag 1/4 na tangke ay iilaw na ung dashboard pag palusong ka?salamat
    Quote Originally Posted by glxexurb View Post
    halos lahat nang sasakyan ay ganyan. para mabigyan ang drayber ng warning at makahanap ng gasolinahan.
    isipin mo na lang kung mag-fuel warning at pagtapos ng isang kilometro ay tirik na...
    mabilis bumaba o magpalit kapag 1/4 or less? it has to do with the gas tank's shape.
    personally, i do not think you need to change anything. my brand new car is like that..
    Oct 2011
    bakit napunta sa edsa revolution?
    ... hindi naman dati ganito...
    pacheck mo na lang fuel gauge sensor/float assembly sa loob ng tanke
    Apr 2009
    Your fuel float (fuel gauge sender) has seen better days & is better off replaced with a new one for accurate fuel level reading. This is usually the longterm outcome if your habit is to fill your tank with a few hundred pesos with your guage in the 1/4 or almost empty state (with the "fuel low" indicator on). This happens since your tank rarely gets full as most of us refuse to fill our tank full for financial reasons. What happens is the the electronic contact points in your fuel sender gets worn out in the lower 1/4 - near empty area. As the contact point areas becomes worn out overtime,This will later on register in your gauge as erratic fast low or fast empty on your gauge & also at times on inclined areas it seems to be ok or gives an inaccurate reading.
    This is easily corrected with a new OEM float. Yes OEM. Surplus is ok as long as it is in a good state. I dont advise replacement brands as they give inaccurate readings too
    Feb 2013
    maraming salamat sir sa input mo.ganun cguro halos tama lahat sinabi mo.bihira nga tau magpakarga nang matagal sa gasolinahan hehe.parang humihinto lang tayo saglit pag umiilaw na yong kulay orange sa dashboard hehe.
    Apr 2009
    If your on a tight budget, some meticulous car electricians can build up with a solder the worn out contact points of your fuel float/sender. (That is if your fuel float is still "salvageable"). Brandnew OEM is expensive at P5k up depending on your car model but is the most accurate & sure fix to your woes...
    Apr 2012
    normal lang yan na mag-warning light less than 1/4 ng tangke. kaya inilagay yan para early warning sayo to fill-up lalo na kung mahaba ang byahe mo. since sinukat mo kamo at may 10 liters ka pa na laman ng tank ay magandang basis mo yan. assuming ang ave. fuel consumption ng hi ace mo ay 8 km/li, that means kapag umilaw na ay kaya pa takbuhin ng hi ace mo yung 80kms bago ka itirik
Hindi accurate ang fuel gauge
