Results 1 to 10 of 14
    Feb 2014
    Quote Originally Posted by askals View Post
    sa civic ek 97 vti M/T ko ginawa
    GK + Upgraded Stock Ground without the Alternator wire upgrade
    big image --> http://i42.tinypic.com/335b9f5.jpg
    links na lang... madami at malalaki yung mga pics/images eh..
    materials:
    battery terminals - 250 pair sa DIY hardware or Handyman
    wires/cables:
    gauge #0 welding cable 150 per feet(for all stock/main grounds) - 2 feet lang pwede na..
    gauge #4 power cable/amp wire thin stranded- 120 per meter 100 lang to sa raon -
    yung bili kong 8 meters may sobra pa sa 8 points ko..
    merong mas mga mahal per meter na aftermarkets amp/sounds wires/cables..
    others:
    GK bracket/mount ay galing sa HKS copy na gk.. hanap kang pinakamura..
    hindi ko ginamit yung wires.. pinamigay ko na lang.. 500 php
    ring terminals (7.50 and 25 per piece), battery cover na rubber(50php)
    heat shrinkable wraps (90 and 100 per meter)
    zip ties, lighter (pang-init nung shrinkable wraps, etc..
    you can buy yang mga yan sa mga auto or audio shops, hardware, sa raon and internet(Sulit)
    prep:
    prepare na muna yung battery terminal..
    main ground cable at yung gk mount..
    yung bracket/mount nung gk wires ay binaluktot ko para ma-angulo paliko..
    yung ring terminal para sa gk mount ay binawasan ko mga gilid then pitpit then butas
    http://i58.tinypic.com/28iyzb9.jpg
    so bawas.. pitpit... butas
    eto nga pala yung positive terminal..
    http://i39.tinypic.com/2145url.jpg
    http://i58.tinypic.com/r0dq9u.jpg
    2 ground wires kada points.. pwedeng bawasan..
    A.
    left front frame - nagbutas ako rito sa part na ito..
    http://i41.tinypic.com/2hcj1x1.jpg
    front - sa may latch nung hood banda
    http://i39.tinypic.com/zlrc6g.jpg
    B.
    firewall - may nakausling thread.. ngayon ko lang din napansin heheh.. dyan ko na nilagay..
    http://i44.tinypic.com/28jweja.jpg
    right side body
    http://i41.tinypic.com/j5b0bs.jpg
    C.
    iacv/throttle body area
    http://i59.tinypic.com/2m6oikm.jpg
    distributor/valve cover area
    http://i42.tinypic.com/2jg1an8.jpg
    D.
    starter/transmission area - duon sa isang bolt ko inipit
    http://i41.tinypic.com/33a8cjr.jpg
    alternator - sa may bracket/mount/support niya -
    mahaba yung turnilyo kaya duon ko nilagay yung terminal then ipit ng isang nut..
    http://i40.tinypic.com/2a81cpl.jpg
    http://i43.tinypic.com/5xmvy1.jpg
    http://i43.tinypic.com/2s1w4rq.jpg
    http://i41.tinypic.com/2mx057c.jpg
    http://i44.tinypic.com/m968g8.jpg
    eto yung mga stock ground area na pinalitan ko..
    http://i62.tinypic.com/2j2tdvb.jpg
    http://i41.tinypic.com/rutq3c.jpg
    http://i43.tinypic.com/x514s6.jpg
    note:
    pwede nyo pong bawasan... nasa inyo na po yun...
    pwedeng tong area lang...
    starter
    alternator(top/outside holder)
    throttle/IACV
    distributor/head cover
    right body/driver side
    firewall
    hth...
    sir taga saan po kayo? pwede po ba ako magpa-install sa inyo?
    Aug 2012
    *askals: nice setup brod. good share.
Shops that can do grounding kit installation in cavite area?
