Results 1 to 10 of 10
    Jul 2006
    I bought a set of Bosch EC9C fanfare horns and I want to DIY the upgrade on my Honda City.
    Do I have to buy a relay? What are the steps needed?
    Quote Originally Posted by archerwin View Post
    No relay needed. Just directly replace existing horn with the Bosch horns. You just might need to wire the ground wire to the body of the car.
    Jul 2006
    ghosthunter,
    hello! Thank you! Stupid question: The EC9C has 2 horns, you connect it in parallel right? then the 2 horns will be grounded to the body of the car?
    thanks again!
    ghosthunter,
    thanks again!
    yup... in parallel.
    Jul 2006
    thanks again!
    Tried without a relay and the results weren't spectacular. Had a relay installed. Also relocated the horn to the driver's side where it can be positioned higher and better protected from floods. The power comes directly from the positive terminal of the battery. Added wire hidden using OEM-style wiring covers.
    Yes, ground is direct to body.
Honda City Horn upgrade DIY Questions
