Results 1 to 12 of 12
    Mar 2011
    pa suggest naman san ang recommended electrical shop niyo dito sa south
    balak ko kasi papalitan yung bulbs ng gauge cluster at instrument panel ng crosswind ko from green to blue.
    if ever DIY san kaya makakabili nung condom nung rice bulbs and the bulbs themselves?
    Apologies for reviving this thread - did a couple of searches for electricians in the south but most are already in the Las Pinas / Cavite area. Trying to look for one na Alabang lang sana or along Dona Soledad or Sucat road. Hindi naman kailangang maganda ang puwesto, freelancer oks lang din. Kailangan lang maingat at may mga piyesa rin para sa mga kailangan. Nag-abroad na kasi pareho yung suki ko sa Evangelista at Sucat noon.
    Breakdown ng gagawin, most parts sa akin unless noted otherwise:
    - Inspect / fix rattling noise sa ceiling (nawawala kapag dinidiinan ko yung ceiling cover), most probably loose wire lang
    - Align / replace power-lock motor for 2 doors (hit / miss pag lock at unlock kasi), sa kanya ko na bibilhin to if ever
    - Replace busted fog lamp bulbs (sa kanya ko na rin bibilhin yung bulbs)
    - Fix fog lamp wirings
    - Install OEM steering wheel mounted radio / bluetooth control
    - Install OEM steering wheel headlight lever with foglight switch (install wiring din for turning on/off the fog lights with the OEM switch)
    - Install OEM armrest (optional: baka i-DIY ko na hehe)
    - Install Passive Keyless Entry alarm system (replacement for existing, wonky Winterpine-sourced alarm kit availed by casa)
    - Install Push-Start/Stop Engine Mechanism (kasama ng PKE alarm system - ipapatong sa existing na manual ignition type key switch, baka kailanganin din putulin yung isang susi per install instructions)
    All in one go sana, and reasonable ang singil sa labor. Any advice / contact info will be highly appreciated. Thanks!
    up for this thread. was also looking for reliable electrical shops at muntinlupa, las pinas, cavite and laguna. thank you
    No replies since 2011? Ganon ba talaga ka-rare ang good auto electrical shops in the South? I'm looking for one myself. I've been having intermittent battery draining problems.
    Quote Originally Posted by mjuane View Post
    Jan 2018
    Sir meron sa south laguna nga lang. Check Oanaoan Biņan sa fb.
    Sent from my SM-J730G using Tsikot Forums mobile app
    Jan 2018
    Sa san pedro and biņan laguna madami din
    Jan 2018
    in Taguig area do you know an aircon repair shop?
    Dec 2014
    BUMP!
    Need an electrical shop las pinas or alabang area. pa recommend guys.
    I'm having problem with my starter (Honda car)
    Jun 2016
    BUMP!
    Sir madami dyan along Presidents Avenue if you're near Sucat. Dyan ako nagpa install ng foglamp DRL ko.
    May 2005
    Same here mga boss... saan may magaling mag complete re-wire ng sasakyan. nasunog kasi yung wiring ng sasakyan... buti di nasunog auto.
Recommended electrical shop in the South Area(Las Pinas/Paranaque/Alabang)
