Results 1 to 4 of 4
    Mga sir's need your help,my dim light and wiper switch suddenly stop working.
    Na test na namin high beam ok and when rocking the light switch minsan nagwork dim. For the wiper hindi na talaga nagwork.
    Recommend naman kayo reliable auto electrical sa mindanao ave.
    Thanks
    Quote Originally Posted by tagumpay View Post
    Thanks
    try to inspect the fusebox first. it might be just busted fuse.. consult the car manual..
    if you are a little car-savvy, you can check the headlight bulb. the low beam filament might be busted. sometimes, you do not even need testing instrument. simply looking into the filament will show you...
    as to the wiper, sometimes the wiper motor is ok. but the wiper mechanism disconnected. if you can hear or detect the wiper motor working, then it must be disconnected wiper lever. (now, that! ... is not an easy repair job to do..)
    good luck.
    Finally my wiper and dim light problem was restored yesterday sa Bigboy/btech auto shop along mindanao ave.
    For wiper issue they've found electrical line going to the switch is busted. Works now after replacing electrical line.
    Second dim light, after doing various tests on fuse and switch they located the problem on the grounding line going to the bulb holder. Reconnecting the wire solves the problem.
    Total damage: P800
    good luck.
    Sir sorry late reply..many thanks!
honda city 04 dim and wiper switch not working
