hirap po maghanap ng aftermarket na spark plug wires ng vr v6, i ended up buying OEM for 4k+ last january. same problem, meron sinok and meron tumatalon na kuryente. aling wire/s out of the 6 yung busted po?
Just wanna share my experience with my bros ride when he used hi tension wires on his VR V6. I cant remember the brand name...parang blue thunder or something tapos bosch spark plugs ang gamit namin. There are times kapag nasa daan ka na tapos primera, biglang bumababa ang rpm tapos namamatay ang makina, sometimes naman ok siya. Pero sabi ng mekaniko namin ay gawa raw ng hi tension. Kung gagamitin daw namin yung wires klangan din daw iupgrade ang computer chip. If not, tanggalin na lang daw. So when we had the wires removed, nawala na yung problema. I dont know kung yun talaga ang problema or something else, I just thought you should know just in case it also happens to you.
yep, better to buy the set talaga, kasi malamang bibigay na din yung iba nyan. yung sa akin 1 lang yung palyado actually, pero i replaced the whole set na, then spare na lang yung other 5 wires na ok pa
sirs, what do you mean wen you say sinisinok? eto ba yung parang kumakadyot while moving and enggaged in low gear?
my ride is just a 7Gen SS. thanks mymitsu bro!
yung sa akin po kahit naka-neutral meron sinok, mararamdaman pa din. yep, parang kadyod sya, kasi nagmmiss fire yung isang cylinder, parang pumupugakpukag, hehe best to check at night kung meron nga tumatalon na kuryente, kasi pansin talaga pag madilim. and madidinig din yung parang "pitik" pag nagjump na yung kuryente. also, pede icheck yung resistance ng wires, yung sa akin kasi infinite na resistance nung isang wire, meaning may putol na somewere.
