Page 1 of 2 12 LastLast
Results 1 to 20 of 49
    Apr 2009
    Based on my cars manual it says required wattage for headlight is 55w but i installed it with a 95w osram headlight. Will this damage my battery or alternator?
    Jan 2017
    Quote Originally Posted by bail View Post
    hindi naman cguro..
    Oct 2009
    damaged head light socket.and head light deflector.
    Jan 2017
    Quote Originally Posted by jaypee10 View Post
    anong magandang gawin pag ganun sir? replace ang boung assembly?
    Oct 2009
    Quote Originally Posted by neljimz View Post
    mas maganda pa retrofit projector mo kung gusto mong gumanda ang bato ng headlight mo.
    Bro - It will not.
    But check the socket and the wiring,- one or both could melt down,- depending on the quality/gauge of the material used.
    _/_/_/
    31.6K _/_/_/_/_/_/_/_/_/_/
    Jan 2009
    I believe that for halogen or conventional filament bulbs, anything above 60W is considered off-road use only.
    Mar 2017
    Siguro pag 3 to 4 hrs naka-on yun lights mo eh ok lang. pro pag may long drive ka at naka-on for say 5 to 6 hrs delekado. Ganun din ginawa ko sa ilaw ng tsikot ko dti nalusaw yun kabitan ng bulb. Maybe depends din siguro sa car. Luma na kasi yun car ko kaya baka marupok na rin siguro yun mga plastic lagayan ng bulb.
    Maisingit ko na rin. Anyone may experience sa led headlight bulb? Alam ko maliwanag sya pero kamusta naman ang throw ng liwanag? malayo din ba?
    Mar 2004
    Quote Originally Posted by ElvisIsAlive View Post
    used to have led bulb on a jimny. good for low beam (near the car). bad for high beam(the light seems scattered). but far away reflective signs lits well. baddest for incoming traffic. they flash me.
    Oct 2013
    Quote Originally Posted by baker123 View Post
    yon naman talga ginagawa ng high beam, kaya ka fina flash ng kasalubong mo
    binasa nga ang manual, di naman sinunod, edi FAIL pa din
    Mar 2004
    Quote Originally Posted by Stigg ma View Post
    even in low beam.
    Bro-good for you to realize that [and hopefully, you got rid of your LED headlight - high beam].
    Maraming kapwa natin motorista (including iyong mga naka-motor) - walang pakialam kahit na silaw ang kasalubong nila....
    Sarap tuloy hagisan ng tubig at timba kapag nakasalubong mo ang mga iyan....
    33.0K _/_/_/_/_/_/_/_/_/_/
    Dec 2009
    Higher wattage will draw more current, more current require bigger wires in terms of diameter
    Fail to do so could melt the insulation of your stock wire for that light you just replaced with higher wattage
    The ensuing event is the unthinkable a full blown conflagration because your wires will be exposed and touch each other and short the circuit
    Next thing you will need is a fire extinguisher
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jan 2009
    Like HID, aftermarket replacement LED bulbs installed in optics designed for halogen is a bad idea.
    Agree bro.
    Mabuti na lang "used to have LED bulb" si bro.baker...
    Sa mga nagbabalak dito ng straight conversion sa LED headlights (at pati ang mga naka-motorsiklo),- huwag na ninyong gawin.
    Nakakasira lang kayo ng gabi, sa totoo lang...
    _/_/_/
    32.2K _/_/_/_/_/_/_/_/_/_/
    Agree bro.
    Agreed. Naka LED din jimny ko before. Maliwanag nga. But sometimes i get flashed also. Now, back to halogen na. Nagkabit nalang ako ng wiring kit and Osram Nightbreaker Laser. Brighter than stock na
    Oct 2013
    Agree bro.
    _/_/_/
    pwede naman mag hallogen to LED conversion, wag lang yong chepepay, yon ang nakaka silaw...
    pero kung tested na branded ang gagamitin like Philips X-Treme Ultinon LED with safebeam technology eh panalo yan, talo ka lang sa presyo, pero kung madami ka pera, why not...
    X-treme Ultinon LED car headlight bulb 12953BWX2 | Philips
    Jan 2009
    At that price, it's almost in the territory of a quality projector+HID retrofit. And at least currently, it seems to be only available in 6200K only.
    Aug 2012
    There are alternatives to Philips Ultinon LED now with lower price. They use genuine Philips ZES LED chips.
    Sent from my ASUS_Z010D using Tapatalk
    Jan 2009
    Quote Originally Posted by red_one View Post
    Asked about these from a local online seller and all they can offer is 1 month warranty for it. For something that costs 4-5k a pair and a claimed lifespan of >30,000 hours, they don't seem to put much faith in the product.
Headlight wattage
