Page 1 of 2 12 LastLast
Results 1 to 20 of 82
    Aug 2007
    Has anybody tried to install Bosch Europa's?
    I just got mine and noticed that the connectors do not indicate polarity for positive and negative.
    Are they interchangeable?
    Aug 2005
    mind posting pics?
    Aug 2007
    Here you go:
    may polarity po yan. btw hindi lang tutunog pag nagkabaligtad - no need to worry.
    Aug 2007
    Thanks will check it out!
    Aug 2005
    hmmm... yung europa ko parang may + - ah?
    anyway tama di nga tutunog yan pag baliktad just make sure meron kang inline fuse at relay
    Aug 2005
    Quote Originally Posted by augustus View Post
    ala polarity yan. use large gauge wire pra maganda tunog masmaganda kung tig-isa na relay habang naluluma kc yan naghahanap ng mataas na current eh
    kaya ung iba nasisintunado na at pagrainy season alagaan mo ng WD-40
    Jul 2006
    Slightly OT, do you know the frequency of those horns? The one we bought na standard Bosch "pit-pit" have 420Hz and 335Hz for the high and low tones respectively. TIA ;)
    Aug 2007
    Thanks everyone for your inputs.
    I started my installation yesterday and did a few tests and here is what I found.
    1) The horn's metal parts cannot be grounded.
    2) The terminals must be connected to + and - connections and are interchangeable.
    mbeige, in answer to your question, the horns frequencies are 300Mhz and 375 Mhz. I have heard of some people fine tuning and adjusting the horns to a higher frequency but haven't yet discovered on how it's done.
    Jan 2003
    yan ba yung aluminum face? madalas gamit sa old benz? kasi kung yun nga, madali ng sya masira pag nababasa.
    don't tinker with the frequency magloloko yan. but if you really want to tinker with it, its that black glue-like thing near the word bosch. you'll have to remove it the you will see a screw inside which you can turn to adjust the tone.
    and like Joey said put a relay, it needs a strong stable current.
    Mar 2003
    any remedy kung medyo ngo ngo na yung sound ng europa? been using mine for 5 years ang pangit na ng tunog. should i try adjusting the frequency?
    Sep 2005
    Bossing, baka naman 300 Hz and 375 Hz. Generally, humans can only hear sounds up to around 20 kHz (0.02 MHz) in frequency. mbeige, your standard Bosch should have higher tones than the Europa.
    Jul 2006
    Yeah you're right the standard Bosch ones are 335Hz and 420Hz for the low and high tones. Dapat pala Europa kinuha ko hehe oh well I'm back in the US...
    I think the adjustment is only for "recalibrating" kapag wala na sa tono kasi I tried adjusting the new ones we got (standard Bosch for the Civic) and they're pretty much the same sound. Overadjusting resulted in a nullified effect nawala yung tunog ng isa (yung adjusted) kaya balik sa dati ayun bumalik. So I think you can't change the frequency of the tone di mo pwede pababain it's in the material I guess...
    Aug 2014
    Mga sirs question about bosch europa silver. Kaya ba imount sa likod ng mesh ng bumper or sa grille? If pede sa bumper, kelangan ba baklasin or pedeng hindi na?
    - car is honda jazz ge 1.5v(facelift)
    Thanks in advance.
    Jan 2010
    Sorry for resurrecting a very old thread. Does anyone know the right Amps to use for the Relay and Fuse for 1 Bosch europa?
    Apr 2010
    i used a 30A Bosch 5 pin relay and a 10A fuse, commonly available on auto supply stores.
    it is working for around 4 years na, lumalim nga lang tunog over the years conpared to a newly installed pair
    Jan 2010
    Quote Originally Posted by ParticleX View Post
    Thanks! Got the parts na. Weekend project na.
    Mar 2013
    Pa share naman paano kinabit with relay.
    Sent from my Lenovo P1a42 using Tsikot Forums mobile app
    Quote Originally Posted by fleettkr View Post
    errr... can't you use the old relay and wiring?
    just disconnect the connections to the outgoing horn and connect them to the incoming horn?
    perhaps your outgoing horn has similar electrical requirements as the incoming horn?
    Doc, OEM horns, because they're meep meep meaning they do not draw so much current, no relays,-direct connection to the switch....
Bosch Europa Horn Installation
