Results 1 to 6 of 6
    Jan 2003
    paano maaayos ang power window na nag-stock-up? may panglinis ba dito? paano maayos ito?? hinfi kasi nagtutuloy pag sinasara mo yun bintana
    Lubrication lang yan. That was the problem with my rear left window. Went to chieffy's and we both opened up the door panel, sprayed wd40, loosened up the railings, and presto, it worked!
    Jan 2003
    i have the same problem on the driver side window... ang hirap isara...
    paging chieffy! i will be passing by your shop this afternoon to have it checked... sana maayos din... thanks...
    spraying the railings with WD40 or other oils will only temporarily freeup the stuck window.
    ghost, naglagay din kami ng hi-temp lithium grease sa mga railings sa loob ng pinto....
    sige po ma'am shock...hintayin ko po pagbalik nyo...
    ito po yung sample pic
    Jan 2003
    chieffy, late na natapos meeting ko sa oil depot yesterday dyan sa Pandacan, at bawal pa mag celfone dun, hindi na ko nakapagtext. Hindi na ko nakabalik ulit kasi madilim na din. I'll drop by your shop again anytime next week. Text na lang kita. Thanks.
    Halos ilang months ko na din hindi nagagamit yung window ko sa driver's side kaya ang hirap, nagbubukas pa ko ng pinto...
power window
