Forums
Discussions
Events
Community
April 6th, 2005 08:05 PM
mga guru,
ask ko lang, ano kaya possible cause nito...
whenever i floor the brake while the engine is on idle (car not running) bumababa ung rpm ng engine. kapag naka aircon naman ako and i brake the engine stops.
TIA!
mitsu lancer '89 glx ride ko...
April 6th, 2005 09:31 PM
the brake uses power from the engine to boost the brake fluid pressure.
April 6th, 2005 09:34 PM
hindi ba masyado mababa ang idling speed mo?
Signature
April 7th, 2005 02:23 AM
ok naman yung idling speed ko. 1200rpm.
April 7th, 2005 08:01 AM
isn't your idle speed a little high? di ba dapat around 800 to 900 rpm?
April 7th, 2005 08:42 AM
Check vacuum lines to brake booster and brake booster itself.
April 7th, 2005 10:03 PM
April 7th, 2005 10:34 PM
Your idling is too high, have it checked.
April 7th, 2005 10:47 PM
taas ng idling, siguro kinalikot yan ng mekaniko mo (sana hindi ikaw yun ehehehe) para maremedyuhan yung namamatay na engine mo.
add mo din sa i-check mo, ignition timing baka off kaya need na high idle yan engine mo. when was your last tune up?
April 8th, 2005 08:46 AM
carb yan diba, check the vac hoses
April 8th, 2005 09:30 AM
carb ba yan? If so vaccum. if fuel injected dami causes
April 8th, 2005 08:10 PM
mataas yung idling ko kasi sira yung solenoid valve na automatic na nagbubukas when you open the a/c.
but now, i decided not to use the a/c (kasi nga namamatay when i floor the brake). 800 - 900 ang rpm idling speed ko.
i'll check yung vacuum hose na yun, by now hindi ko pa maCheck. busy kasi sa work.
carb yung auto ko.
tnx sa mga respondents!!!
