Results 1 to 6 of 6
    mga sir..patulong naman..na check ko lang this morning when i was cleaning my engine bay, pag kapa ko dun sa tension wires sa my spark plugs. napansin ko yung isang tension wire ko nasunog. pag tangal ko sa tension wire yung spark plug medyo sunog din. ano kaya nangyari dun?
    it could be a loose connection creating a hot spot along your wire. If the burned area looks bad, it might be time to replace your wires.
    Mar 2005
    dittto
    Quote Originally Posted by ghosthunter
    loose nga lang kaya yun? ok naman yung pag ka fit sya sa spark plugs..kasi before bago ako ng palit ng tension wire ganun na rin eh..then i bought a new set of wires at spark plugs..kala ko that will solve the problem..kaso hindi pa rin eh.. sayang kakabali ko lng nung tension wires. palit na naman.
    sa same cylinder ba yun twice na nasunog? bad grounding on that particular spark plug hole maybe? baka may carbon dun sa threads ng butas kaya nagiinit yung plug na nakakabit dun.
    Quote Originally Posted by yebo
    sir yebo same cylinder. pero before tolerable naman. minsan mag start ka sa umaga palyado check mo yung spark plug may deposits,tapos kunting liha lang ayos na ulit ang takbo. kala ko naman buying a new set ng spark plugs at tension wires will solve the problem di rin pala.
help: tension wire nasunog..
