just wondering: turbochargers use exhaust pressure to turn the compressor right? why can't we do the same for A/C units? it would free up the load on the engine di ba?
first problem, turbochargers do not produce that much torque to turn an a/c compressor.Originally Posted by badkuk
second problem, turbochargers rotate at speeds at least 10 times faster than the a/c compressor maximum rpm. You will need some sort of speed reducer to mate them together.
third problem, turbochargers do not operate at low engine speeds, which would mean no cooling at idle and cruising speeds.
1 and 2 nd problem can easily be solved by gear ratios, High RPM and low torque can be converted to a high torque low rpm through gears.
3rd problem is the only one left
that's easy to do! we can use SuperCharger Technology (TM) to turn the A/C compressor! oh, wait... :D3rd problem is the only one left
akala ko khaos na naman heheh lahat ng problema sa kotse kaya ng khaos?
another problem, I think.
since you are using your exhaust as a power system - wouldn't this strain the engine (to expel the exhaust gases)?
for turbochargers, this isn't a problem since they would give additional power to the engine in a mutual give & take situation (more exhaust -> faster turbo -> even more exhaust -> etc).
true but the RPM range will still be very wide.Originally Posted by Mojo
And if you do use gear reducers, won't it greatly decrease the efficiency of the system and increase it's need for maintenance as well? Gear reducers will require lubricating oil which would require periodic maintenance as well. Then there will be a problem of packaging of the entire system compactly under the hood with weight comparible (or less) than a standard a/c compressor system.
And the last thing... cost of the system might be 3 to 4 times more than a standard a/c compressor. I'd rather have that added cost into producing more engine power.
A better way would be a conversion to a higher output alternator and an electric PS pump and electric A/C. Although where you'd get one here, I have no idea. Hybrids in the US run on electric ACs with no problem... newer models here are getting electric steering racks... heck, you can even make the water pump electric! Having just one parasitic device on your engine (the alternator) can make a big difference, even if you have to enlarge the alternator to run the other devices. AFAIK, differences due to an all electric system equate to maybe 1-2mpg savings.
masyado atang mabigat ang ercon para sa exhaust gases.
sa turbo kase hangin lang din dina drive nya di ba di ba
The A/C system and the engine's induction system have different flow and pressure requirements. The engine needs a high volume, though relatively low pressure charging system, while the a/c or power steering systems need a low volume, but relatively high pressure pump.Originally Posted by badkuk
The difference between a turbine-driven compressor and a piston or vane-type pump is analogous to that of the spoon and fork. Both are used for a similar purpose, though they have their own special uses.
mabigat ikutin ang compressor mlamang bago mapaikot ng exhaust eh nabulunan or bog down na engine. unlike s turbo freewheeling un slight difference ng load ang ndadagdag lng abve 2500 rpm. ive heard smeone p nga bkit daw hnd s propeller or axle ikbit ung cmpressor (hahaha) nd use electrical pwer at idling hehehe
