Results 1 to 6 of 6
    Jan 2010
    Good day mga bossing!
    Paano mo malalaman na ang alternator is undercharging?
    Meron bang aparato or tester na ginagamit ang mga electricians to know if the alternator is undercharging? Pwede ba maging cause ang carbon brushers aside sa IC?
    Pwede rin ba maging cause na tumaas temperature or mag overheat due to continuous run ng aircon compressor dahil sa insufficient supply ng kuryente coming from the alternator?
    Any suggested repair shop ng alternator near Sta. Rosa, Laguna? Or surplus shop na nagbebenta nito within laguna? I've tried to contact Nagano surplus shop pero wala sila binebentang alternators. Sana ung mura lang.
    karamihan trouble sa 96-99 alternators yung voltage regulator ,kaya pag binuksan na yan check na rin yung stator ,brushes and field coil.pati na rin yung rectifier assy .kung minsan palit bearings na rin,
    at idle no load a least 14.5v
    at idle full loads at least 13.5v
    at 2500 rpm no load max 14.8 v
    yun ang typical readings na sinusunod ko .these can be done by using a digital voltmeter.
    Jun 2009
    The best way to check the charging system of a car aside from voltmeter is by using battery/ alternator tester wherein you could monitor the condition of rectifier/diode, IC regulator and charging voltage. Once the trouble is pinpointed, try to source for parts that needs replacement. In my experience, once the stator, rotor is defective, the best way is to replace the whole alternator itself since rewinding these components will not give satisfactory results (insufficient voltage and current). The best equipment I've used so far in diagnosing charging system is Snap On Microvat wherein it will diagnose what component is defective just by plugging the leads on battery terminals.
    Jan 2010
    Quote Originally Posted by bambino View Post
    Meron pa bang voltage regulator ung alternator? Diba pag may IC na ang alternator wala na voltage regulator?
    Quote Originally Posted by advatech View Post
    IC means voltage regulator iisa lang yun bro.
    Jan 2010
    Meron ba kayong recommended repair shop ng alternators here in sta. rosa, laguna? Sana ung mura maningil.
Honda Civic VTEC 96 Alternator undercharging
