Results 1 to 14 of 14
    Ano po kaya problem nito? Pag on yung ignition naka on yung ilaw ng mga yan and the car won't start. Wala naman problem nung nag park. Nung gagamitin lang ulit saka nagka ganyan. I checked the dip stick ok naman oil.
    Jan 2016
    Baka battery mo mahina na
    Jan 2009
    Maalikabok kaya ayaw mag start.... j/k
    With the engine off and the ignition switch on, normal ganyang indicators.
    Normal ba yung redondo (ie. mabilis ba)?
    Koneksyon ng baterya, baka maluwag lang.
    Sent from my INE-LX2 using Tapatalk
    May 2017
    mahina na battery mo, use a voltmeter/multitester to check the cranking volts of your battery
    i agree.
    weak battery.
    that display is normal for every other car when the ignition is set to "on", but not yet to start.
    even cars with batteries too weak to start the engine, will show that display.
    it is very common to experience the "ok naman battery ko when i last turned off the engine a few hours ago. so why can't i start the engine now?" syndrome.
    batteries do deteriorate very fast, when it is time to go.
    ...car started fine this morning at home.
    drove to work.
    car won't start in the afternoon.
    ...drove to the mall, no problem.
    car wouldn't start 2 hours later.
    common scenarios of weak battery.
    Apr 2014
    Also, there might be white substance forming on the battery terminals. Just clean it
    motolite's delivery service to place-of-strandment is great.
    i do not know if the competition has something even remotely like it.
    Amaron dealers offer free delivery within key metro area but it’s not 24 hours though.
    bro altis ba yan? normal yata yan kasi ganyan sakin except for the battery light.
    post ko sakin later
    engine off and engine ON bro
    hth
    Jan 2009
    post ko sakin later
    The actual issue he's having is, it won't start.
    opps my bad
    Weak battery na yan.
Oil light, engine light, steering wheel light and battery light.
