Results 1 to 3 of 3
    Nov 2006
    next inquiry lang mga tsikot experts, recently lang kasi yung power windows ko sa front passenger side bigla nlang nagloloko.. most of the time, fully functional naman. pero may times na pag ibinaba ko, di na mai-close or di na umaangat. nung pina check ko sa electrician after ma stuck na nakababa, sabi nya kinalikot lang raw nya yung switch sa passenger side tapos gumana na ulit. then after a couple of days, balik nnman yung problema... di ako convinded na yung switch sa passenger side yung culprit kasi pag nagloloko sya, pati yung switch sa driver side di rin gumagana. pero pag di nman nagloloko, both switches are working fine. yung motor na kaya problema? if ever yung motor nga, naayos pa ba yun or replace na agad? hassle kasi, di ko na maibaba dahil worried na baka di umangat.. last time na na-stuck, inabutan pa ko ng ulan.. hehehe
    thanks in advance...
    Jan 2009
    puedeng motor puede ding un cord lang, pacheck mo sa suki mong electrician - pagcord palitan mo ng cable para break ng bike mas okay un. ganyan din nangyari sa akin so far okay nasiya. mahirap lang niyan pagpinatagal mo mabasag un salamin. kaya paayos mo na.
    May 2007
    There is a circuit breaker block on the fuse panel.It is probably kicking out when it gets hot and then resets itself when it gets cold again.Replace the breaker. Also, also you must clean all the switch box. Spray WD-40 over the switch and into the wire terminals use a stiff brush to clean on the switch and into the wire terminals, an old toothbrush will work. Dont forget you need die-electric grease for the terminal to stop corrosion.
motor kaya or switch lang?
