Results 1 to 9 of 9
    San ba mas ok magpaayos ng electrical problem? Ayoko sa mga tabi tabing shop lang may mga bad experience na ako.
    Jan 2009
    Quote Originally Posted by a3n3as View Post
    Maybe you can add details kung anong "electrical problem" meron ka? Too vague.
    I’m assuming alternator issue?
    alarm and tail light on one side is not working, also sa auto lock remote ayaw din gumana
    Jan 2009
    If aftermarket, the alarm and remote auto-lock is probably the same module. Fuse, maybe? Loose ground point?
    The tailight problem could be something else.... If the whole assembly on that side is not lighting up or lights up in an unusual manner, it could just be a grounding point issue.
    It's far-fethed but if the tailight and alarm module are using the same faulty ground point, that could potentially be the root cause.
    Feb 2024
    Before this happened, did you change anything having to do with the electrical system like a light bulb (from incandescent to LED)?
    Feb 2009
    Properly identify make, model, year and option. State the symptom,frequency of occurrence, weather, road conditions, time of day, abnormal smells, vibration and noise. The more detailed, the easier to get help specially when the subject is not in sight.
    errr,
    what vehicle are we talking about, po?
    Sep 2010
    And taga saan ka ba? If from QC, try Wizzard sa may Tomas Morato.
Yock's or Rey Electrical
