Results 1 to 10 of 14
- Jan 2018
- 1
January 10th, 2018 01:06 AM #1Hi, i would like to seek some advice or help.
I have Montero VGT model 2013 and recently im experiencing starting problem when the engine is hot. Meaning when I start it for the first time, there is no problem but after few minutes of running and I turn it off then turn own, It would not start and need to cool down for at least an hour thne it will start like nothing happens.
I brought it to MMC Pasong Tamo and they replace the plunger solenoid valve and fuel filter but nothing happens. Then I broight it back and now they are saying the problem is in the common rail but I start to doubt since its running ok but only having starting problem when its hot and I am thinking maybe te faulty one could be sensors or minor instruments and not this expensive common rail...
please help and hope to hear some advise for second opinion. Thank you.
January 10th, 2018 01:10 AM #2
zix performance has a complete set of diagnostic tools to check your engine. update us once you finish your visit
- Jul 2009
- 153
January 12th, 2018 04:26 PM #3Ayaw mag start Montero mo? Consider yourself very lucky and blessed! Yung sa iba kasi ayaw mag stop!
January 12th, 2018 07:32 PM #4
When the crank-no-start condition happens, or you think it has a pattern of a no start, check if the ignition is able to deliver spark from the ignition coils.
January 12th, 2018 07:37 PM #5
diesel engines have ignition coils?
January 12th, 2018 07:50 PM #6
January 12th, 2018 07:54 PM #7
i only have questions
January 12th, 2018 07:56 PM #8
January 12th, 2018 08:05 PM #9
This vehicle must be OBD II compliant. Why not have it scanned first?
- Jun 2025
- 1
June 17th, 2025 06:50 PM #10
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
