Results 1 to 6 of 6
    Mar 2007
    Mga sir, ano ba problem pag wala man lang kayong maririnig na click, redondo, etc pag nagstart? Were having the bizarre problem lately.
    3 months ago ay pinababa ko na ang starter at napalitan na rin ng carbon then umokey na.
    Last month lang the problem occured again at dinala ko uli sa trusted electrician, ang sabi ay sa susian na daw ang problema kaya binaklas nya ang ignition switch at niremedyuhan. Ang sabi pa nya ay mejo upod na daw ang platino kaya pag bumalik uli ang problema, advise nya ay palitan na ng buo ignition switch.
    Minsan lang naman mangyari ito mga sir, perhaps in 100 times ko na ginamit ang auto ay twice pa lang nangyayari ito.
    1st and 2 starts ay walang click, then sa 3rd try ay mag-start na ang engine.
    By the way, magkano ba ang ignition switch for nissan stanza 86 model...and san shop po ba meron ng ganitong pyesa?
    Thanks and more power!
    Feb 2009
    Quote Originally Posted by CarPainter View Post
    is the car equipped with automatic transaxle or manual transaxle? check the PRD2L ( prindle) switch for atx, or check your clutch inhibitor switch and relay for mtx
    Mar 2007
    jick,
    Where specifically can I see the the clutch inhibitor switch and relay...what does it look like?
    After Ive seen those, what would be my next move or troubleshooting to do?
    Is it possible if I DIY it first before going to the electrician?
    Thank you
    Feb 2009
    jick,
    Thank you
    your clutch inhibitor switch is attached underdash just like the brake switch, it is activated by the clutch pedal. the relay is on the relay block, it should be marked inhibit relay or starter relay
    Jul 2005
    hope this helps...
    [ame="http://www.youtube.com/watch?v=CxjPpytfnv0"]YouTube- how car starter motors work[/ame]
    Mar 2007
    Quote Originally Posted by duncan_sheek View Post
    Duncan, thanks for this very informative video
No click in starting the engine
