Results 1 to 12 of 12
    Apr 2012
    Sirs quick question lang. Normal ba na madischarge battery pag di ginamit ng ilang araw (5-7 days)? Yung battery ko bago lang mga 5 months pa lang. It happened one time pa lang naman, but I'd like to know if its normal.
    Thanks!
    Oct 2011
    5-7 days? Not normal sir.
    Posted via Tsikot Mobile App
    Apr 2012
    Thanks sir.
    Ano kaya possible problem pag ganito?
    Nagtataka nga ako considering na bago pa lang battery.
    Oct 2011
    Quote Originally Posted by eliah View Post
    Thanks sir.
    Meron akong coding na sasakyan once a week lang ginagamit and no problem kada start ko. Hindi naman kasi agad mawawalan ng charge ang baterya. Baka may problema alternator mo sir kaya hindi kumakarga ng charge baterya mo or pa check mo muna baterya mo kung may problema ba. Meron ka bang ni install or nagalaw na electrical sa sasakyan mo sir?
    Jun 2012
    Thanks sir.
    Pa re-charge mo yung baterya, then leave it for a week. Wag mo ikakabit. Pag na-discharge pa rin, ibig sabihin palitan mo na or claim for a warranty. Pag hindi na-discharge, pa-check mo oto mo baka may mga accessories na continuous na umaandar kahit nakatanggal ang susi.
    Apr 2012
    thanks for you inputs bros.
    My car is first gen Vios 1.5G matic. Wala naman akong ibang gadget na naka-on and I also dont use the alarm pag dito lang naka-park sa bahay. Will do your suggestions and have the car check.
    Thanks
    Dec 2009
    kung walang parasitic drain and no devices are left turned on dapat hindi...(provided that battery is at a good status)
    pero i would highly suggest na kung iiwan mo sir ng 1 week yung car at hindi gagamitin for that duration,, tangalin mu negative terminal sa battery, very easy to do po and will put you at the safe side...
    kung meh parasitic drain kasi usually hours lang yan or overnight mu lang maiwan ma dead agad battery...
    1. check battery status
    2. check for any parasitic drain
    Jun 2012
    Thanks!
    Saan ginagamit ang baterya boss, sa auto ba o sa gadget?
    Ang ibig mo bang sabihin pag hindi ginagamit ay nakatanggal ang baterya? O, hindi mo ginagamit ang gadget o yung car?
    Mar 2013
    Thanks!
    Eto din nangyari sa car na iniwan namin dto after xmas vacay in the mountains. Ayaw magstart ngayon! Hehe. Though sabi ng kapitbahay, buong gabi naman daw nagalarm nung new year.
    Sent from my GT-I9505 using Tapatalk 4
    Thanks!
    nope. not normal.
    i routinely leave my vehicles un-attended for 2 weeks. they all easily start one-click lang afterward.
    so what are the possibilities?
    1. your battery is slowly dying. yes, even if it's only 5 months old. it's called "factory defect". have it checked at the battery shop.
    2. your alternator is defective. have it checked at battery shop or alternator shop.
    3. your alternator's rated output is too small. (napalitan ba dati?) look at the etiketa pasted on it and see if it is adequate for your car.
    4. you have too many appliances eating up the alternator's output. bawasan mo, or get a bigger alternator.
    5. you have loose electrical connections. check 'em.
    6. you have big parasitic load. kumakain ng kuryente kahit patay ang kotse. have it checked by a specialist.
    (you can check this using my juan tamad method.. disconnect your battery cable. re-connect after 7 days and start the engine. if it starts, then you have parasites. if it doesn't start, either your alternator is insufficient, or your battery is dying..)
    btw, what vehicle are we talking about? and do you have many electrical toys in it?
    Sep 2010
    not normal, kahit one month mo hindi gamitin yan, hindi dapat ma diskarga, unless may naiwan kang naka switch on sa sasakyan mo like map light stereo...
    Feb 2009
    If the alarm was constantly triggered by the exploding fireworks/firecrackers, obviously the alarm eats up the remaining charge
Normal Ba Na Madiskarga Battery If Di Ginagamit For A Week?
