Results 1 to 15 of 15
    Hi Guys.
    Tanong ko lang sana kung may nakagawa na sa inyo na maglagay ng maliit na chest freezer sa vehicle nyo. I'm planning to buy a small chest freezer at ilagay ko sa van ko for long road trips tipong 3 cu.ft. in size. Ang tanong tatagal kaya compressor ng freezer kung naka ON siya habang umaandar yung vehicle?
    Thanks
    Apr 2011
    Quote Originally Posted by erick_214 View Post
    Hi Guys.
    Thanks
    If your van is big, you can get a standard 3 cu.ft ref/freezer and get an inverter rated around 150W that plugs into the cigarette lighter outlet. Just make sure the refrigerator sits on a level surface of the vehicle.
    Feb 2009
    There are lots of stores along the way. Or you can use an ice chest packed with ice and your cold drinks or food. Travel light and save fuel
    What are you planning to keep in the freezer? IMO, it doesn't make sense.
    Feb 2009
    Exactly! We transported human remains, human blood and all it took was reicing at regular intervals
    150W inverter? e starting current nyan nasa 6 amps, so x 220V = 1320W. you'll need at least a 2000W inverter to be safe. and also need to change your car battery to a bigger deep cycle battery.
    tama si jick, cooler with ice lang katapat nyan mura pa.
    eto pang cold drinks lang, kasya 6 cans. electronic, walang compressor. meron din libre nyan sa duty free pag bibili ka ng 2 packs ng chocolate.
    Attached Thumbnails Attached Thumbnails 20150304120230-olxbd810360b85bda337ef2f72ea4196987b981581c.jpg
    Kung for beverages lang and fruits for long travels. Pwede na mga Coleman/rubbermade coolers. Kahit na yun mga murang styro coolers lang pwede na rin.
    Sep 2013
    optional lang. buy ka ng ice gel ng 2 to 4 bags pero depende sa styro coolers size. kahit isang araw pa yan guarantee di totally matutunaw basta ang ice gel matigas taken out from ref.
    Ang cute!!! Gaano kaya kalakas sa kuryente yan?
    There is what you call ThermoElectric or Peltier cooler. It was once a space age technology used to convert heat to electricity/a thermo electric generator.
    tipid siya maam cathy kasi electronic, peltier effect as mentioned by 12vdc. i have the blue one, libre lang from duty free. keeps the chocolates from melting and soda cool in my van. the hello kitty sells for around 2-2.5k. also these can run either on 12 vdc car power or 220 vac house current so pwede sa bedside table mo.
    Hi sir, balak ko kz pag nag out of town kame may madadala kameng pang bbq o pang ihaw na marinade na. Sa cooler kz sumisingay pa rin un amoy kahit paano. Tapos para pag uwe naman bibili kame ng mga pwdeng bilhin para pasalubong na rin. Tsaka syempre mga drinks pag nag swimming at saksak na rin sa outlet ng resort.
    Pano kaya yung mga chest freezers may nakita ako na Fujidenso 2.3 cu in lng. Hindi kaya masira agad compressor nito pag naka on habang umaandar yung van or may freezers talaga na pang moving vehicles? Tnx
    Jan 2014
    Cooler with ice and salts lang pwede na siguro. 10 hours yung trip namin balikan kasi. Pagkauwi yung ice cream na baon namin matigas pa rin at yung mga bottled water nagyeyelo. 2 packs ng 711 ice lang ginamit ko, 1 papunta at 1 pabalik.
    Hi Guys.
    Thanks
    you should've included the power characteristics of that freezer (ie. voltage, current, watts / power, etc.).
    assuming the ref is rated 220Vac, 150Watts, 1Ph, 60Hz:
    you will need a single phase inverter:
    Continuous output power: at least 500 Watts
    dc input / operating voltage: 10 to 15 Volts *
    Output voltage: 240 Volts ac *
    Output frequency: 60 Hz +/- .05 Hz *
    (*) ratings usually used by american made inverters
    'yung malalaking SUVs at 'yung mga ice cream rolling stores lang sa middle east ako madalas makakita ng ganyan.
    wala naman akong large SUV... tama na sa akin 'yung styro coolers. :thumbup:
    of course. refs / freezers are supposed to be plugged- in 24hrs a day. mas lalo sigurong madadali ang buhay niya
    kung araw- araw eh on- off- on- off. kapag umaandar ang vehicle, siyempre umaandar rin ang alternator.
    cmiiw, the alternator helps your battery to power up the electricals on your car, that includes the inverter.
    madi- diskarga agad ang baterya mo if your engine is not running and the power of your inverter is coming directly
    from the battery. hth.
Chest Freezer for Cars
