Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 193
    Aug 2010
    Sirs, ask ko lang. Critical ba yung amp rating ng mga battery booster cables? Sa 2.0Li na engine ano dapat rating?
    TIA.
    Quote Originally Posted by alfonsomiguel View Post
    TIA.
    In my experience, YES. Lower AMP rated cables simply cannot carry enough current to crank-over the stalled car and just end up getting hot and may even melt through their insulation. But it does not really matter if the car is a 1.3 or 2.0L ....
    Aug 2010
    Thanks alot Sir.
    Feb 2009
    Most commercial jumper cables are 4 American wire gauge size do automotive use and will suffice for a 1.3 liter gas engine
    So what's the ideal AMP rating to buy at the least?
    Maybe 400 or 500 amp cables....
    Also aside from the wires, check the quality of the clamps.
    ^Thanks.
    I had one of those cheap 250 or 300amp ones before. It broke (the clamp in particular) after we tried jumpstarting my neighbor's Beetle. :D
    On connecting jumpers:
    1. Red (+) on the drained battery
    2. Red (+) on the good battery
    3. Black (-) on the good battery
    4. Black (-) on a chassis/ground point on the car with the drained battery.
    This is correct right?
    Jan 2009
    Do note that the larger the engine displacement, the larger the cranking current. Also, Diesel engines, due to the nature of their design (higher compression ratio), will also have higher cranking current requirements compared to a similar-displacement gasoline engine.
    ^Thanks.
    I had one of those cheap 30amp ones before. It broke (the clamp in particular) after we tried jumpstarting my neighbor's Beetle. :D
    Yup, and 4 to 1 when you remove the jumper cables.....
    BTW, where is Master LSB?...
    There is more to the story than jumper cables.... :naughty2:
    20.0K:lollipop:
    ^Thanks.
    vinj, this was discussed in the thread of C4U weeks ago. dapat daw (+) to (+) then (-) to (-). si uls yata nagsabi nun hehe
    Oct 2011
    Amp rating should be 400A at the very least. Check also the gauge of the copper wire itself.
    i used store-bought jumper cables to start a 10 wheeler truck (V10 diesel) ayaw mag start hehe
    uminit lang yung cables
    so we made our own jumpers using welding cable and heavy duty clamps
    For our delivery trucks, we just swap the batteries to get it started. Store bought jumper cables doesn't help.
    ^Thanks.
    direct lahat, hinde na kailangan yun ground...I think ha...meron naman post for both + and - eh
    Aug 2004
    Not recommended daw negative to negative How To Jump Start a Car | The Art of Manliness
    My friends also used welding cable before when they relocated their batteries to the trunk.
    I recall my dad's old BMW had a jumper cable terminal since the battery was at the rear.
    It was something like this:
    ya store-bought jumper cables are only for cars
    mga trucks/heavy machines nakadisplay nadidiskarga ang battery so we put 2 4D batteries on a pushcart (naka-series 24V)
    yan ang pang jumper namin
    negative to negative works fine for me
    same with me
    Aug 2004
    That's good. One less thing to forget Pero dapat positive muna bago negative then reverse to remove?
Jumper cable amp rating
