Results 1 to 7 of 7
July 26th, 2014 07:51 AM #1
Would like to know kung madali lang install aftermarket turbo timer. Nakabili ako used FET TB-308 turbo timer with five wires, colors are red, black, blue, light yellow and white. Anyone can help me or recommend a technician who can install this to my 2001 Isuzu Fuego pick up? My cp# is 09222640171.
Recommended daw sa mga engines with turbo used in long drives, hindi daw dapat turned off kaagad ang engine upon arriving at your destination.
July 26th, 2014 03:02 PM #2
Red: ignition (constant 12v) or positive batt.
Black: ground
Blue: acc
Yellow: ignition on position
White: handbrake
Not sure sa yellow, usually kasi green yung wire sa ignition on.
July 26th, 2014 08:10 PM #3
yup, basta may turbo bro, kailangan mag cool-off muna before shutdown...
taas kasi ng temps inside the turbo, although meh coolant lines para mabawasan ang temps, the oil can still coke inside or degrade faster kung manatili siya,
at least mapa baba yung temp inside the turbo cartridge para extend yung life nito, crucial aspect din ng turbo lifespan ay engine oil quality and filter efficiency.
Certified MB Addict
- Apr 2007
- 2,284
- Apr 2010
- 742
July 26th, 2014 09:00 PM #5Para sa akin a turbo timer is not needed. Just drive lightly 1-2kms before your destination. Still on orig 21 yr old turbo
July 26th, 2014 09:30 PM #6
Ba't kailangan gumastos at kalikutin ang electricals ng kotse when it only takes a bit of discipline to manually shut off the car yourself after a few minutes?
Posted via Tsikot Mobile App
July 26th, 2014 10:35 PM #7
Thank you sa inyo lahat na nag-reply sa query ko. Installed na ang turbo timer sa pick up ko. Sabi ng installer, okey din ang meron, sometimes, pagdating sa destination, in a hurry na makababa kaya shut off agad engine, hindi na makapaghintay, one convenience ng meron timer. Besides, addl gadget sa instrument panel, meron bago other than the usual. hehehe! Thanks again!
For modern cars... people forget that coolants have a lifespan and that they need to be replaced. ...
