Results 1 to 9 of 9
    is it true that lower amp battery well damage the alternator with a higher amp rating? I recently replaced my stock battery but i found out later na yung pinalit kung battery has a lower ampere rating(70 amp) than the stock battery(90 amp). my alternator ampere rating is 90 amp. is this bad for the car specially sa alternator? tnx.
    Jun 2010
    i'm not sure but some post sa carnival thread says na masisira ang alternator when you replace your oem battery with lower ampere rating
    Quote Originally Posted by imperialv View Post
    ano ang ampere rating nya 100? Double check mo na lang at baka masira yung alternator mo..
    btw, my 10 month old rocket battery is now in the dealer for warranty claim.
    Quote Originally Posted by bigeebabee View Post
    wla pong motolite na 100 amp ang pinakamura bosch napagtanungan ko is sa warren sa binondo pero check nyo sukat pag mas mababa sa 100 amp bka magkaproblem alternator nad d tatagal baterya
    will i guess i need to change my battery to oem specs. the problem is its hard to source aftermarket battery for carens with the same OEM specs(ampere rating). no choice but to buy from the casa which is so expensive.
    Sep 2006
    sir val dami na rin nagpalit ng battery ng carens natin pero yung iba di binili sa casa.. baka may alam sila na store..im also planning to change my battery soon(ok pa naman siya as of this time *36k kms)..
    Quote Originally Posted by Hanren View Post
    yung nabili kong battery 4 months ago kasi motolite pero 70 ampere lang. the highest ampere the other battery brand has is only 80 ampere. oem ampere rating ng carens is 90amp. wala akong mahanap na 90 amp na aftermarket battery kahit saan store na kasya sa engine bay ng carens.
    Jun 2008
    Quote Originally Posted by valskie01 View Post
    try niyo POLLUX Distributors sa caloocan... dami nila brands dala doon... madami pag pilian doon... 364-1401... may MOTOLITE, OUTLAST, GS & AMARON sila doon
    me i used AMARON and i lasted me more than 6 years na...
    Jan 2003
    Quote Originally Posted by mbk347 View Post
    WOW!!!!! 60 months warranty!!!!! http://www.amararaja.co.in/pro.asp
    ^^ saan nakakabili and how much kung 1sn batt? parang sulit sa warrant pa lang. may licensed distributor ba niyan sa pinas?
    galing... 60 months!
    Feb 2010
    how much po eto?
bad effect of lower amp battery
