Results 1 to 12 of 12
    mga sir,
    my car is a 1994 altima and i had a problem yesterday after having been parked for quite a time in the mall (mall of asia)...siguro mga 4 hours...when i was about to start the car, ala na redondo un sasakyan pero gumagana yung headlights, signal lights and busina. Mga sir, alternator kya?...i'm not quite sure kung starter lang yun e..and if it's the alternator, sabi ng ibang electrician kapag nissan daw palit na ng buo yung alternator...ala na pag-asa irepair yun specific part sa loob dun sa alternator...is that true??? ..sobrang mahal nun if ever...thanks in advance.
    Jul 2005
    can be the battery is weak or the starter , alternator can be repaired
    Jul 2005
    can be the battery (weak) or the starter , have it check if alternator , it can be repaired
    pwede repair ang alternator. sa electrician ko, kahit na ano pa sasakyan ay napapalitan ang laman loob ng alternator. saan ba loc mo? sa qc area yung shop nya.
    Na rerepair po ang alternator basta tignan mo lang maigi yung shop na nag repair, yung kasi dito sa labasan ng subdivision namin pinupukpok lang yung bearing sa shaft kaya di magtatagal masisira din yun dapat may hydraulic press, pwede din pukpok pero may technique dun
    Quote Originally Posted by viper2lt View Post
    Sir, saan po sa qc electrician nyo? malapit ako qc area eh.tenchu in advans
    Quote Originally Posted by utk505 View Post
    sir, okey pa naman po yun battery...i had it checked. they suspected it might be the starter or alternator.
    Jul 2005
    Quote Originally Posted by kwiksilber View Post
    ok i think its the starter you said that paaandarin mo na car mo wala syang rodondo have your starter checked usual prob. madumi or worn out solenoid or worse replace
    sa sct chuatoco. m.r. hipolito ang pangalan ng shop. look for danny.
    Apr 2005
    kwik, how old is your battery?
    Quote Originally Posted by maverick34 View Post
    sir, i had the battery almost a year na rin....napa-check ko na po sira...sabi electrician ung starter....sabi nya it would take him the whole day to fix it...ganun po ba talaga katagal magfix ng starter?
    sir, napa-check ko na po problem...starter daw un nag-cause ng nde pagstart ng oto....sir, tenchu ha...pupuntahan ko pa rin electrician mo....any contact # po nya kung meron? tenchu..
Nissan Alternator???
